> celica beams 3sge clip, will it fit the cuope
post Oct 13, 2003 - 4:04 AM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
what i really want to know is that if i buy a celica front clip with the beams 3sge engine can i just take everything from the clip and transfer it to a 94 coupe st without any mods or any custom work, like motor mounts and such.
i'd also like to know a place in cali that can get a front clip of beams 3sge.
This post has been edited by KiLisStalker: Oct 13, 2003 - 4:05 AM
Chris Malaqui
Non-running Celica
post Oct 13, 2003 - 11:19 AM
No its like fitting a 3sgte in it. You'll have to get GT mounts and stuff because you have an A series engine and the Beams is an S.
Also, the Beams 3SGE is harder to come by than an ST205 clip.
This post has been edited by Supersprynt: Oct 13, 2003 - 11:19 AM
post Oct 13, 2003 - 12:07 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (Supersprynt @ Oct 13, 2003 - 9:19 AM)
Actually...it'll be a direct swap...since it already comes with all of the mounts and accessories you'll need...;] but yes, if you manage to find a clip, I doubt it'll be less than 5K...
post Oct 13, 2003 - 2:27 PM
H8DC3lica94
Joined Jan 29, '03
From San Diego, CA
so do i need gt mounts? or does it go in direct?
Chris Malaqui
Non-running Celica
post Oct 13, 2003 - 2:42 PM
Sh0gunkid8721
Joined Feb 22, '03
yes you need the GT mounts
post Oct 13, 2003 - 2:58 PM
Doge
Joined Dec 2, '02
From Portland, Oregon
good luck finding an ss-iii clip though. If you do im sure alot of people on here would like to know where and how. So if you do post all the info.
post Oct 13, 2003 - 3:37 PM
Kwanza
Joined Apr 8, '03
From NorCal
QUOTE (Sh0gunkid8721 @ Oct 13, 2003 - 12:42 PM)
No you won't. You can use the SS3 mounts. It's a FWD car, you can use everthing to swap over. The only serious modifications you'll really have to do is with the wiring...
post Oct 13, 2003 - 4:37 PM
3FingersCelica
Joined Aug 21, '03
From Endicott NY
Check
http://www.jspecjdm.net/tengine.htm
They have a 3gse engine, it says for a ST204 so I'm not even sure if they know what they are talking about.
post Oct 13, 2003 - 5:09 PM
QUOTE (Kwanza @ Oct 13, 2003 - 4:37 PM)
if you get a clip you will have the mounts to use, HOWEVER, your going to have to weld them on. SO YES YOU WILL HAVE TO CHANGE THE MOUNTS. like i said you have the A mounts and you will need the S mounts.
Lo-Fi Version Time is now: August 25th, 2026 - 4:25 PM
