> fs:Turbo Kit - CHEAP
post May 5, 2009 - 4:56 PM
baktasht
Joined Jan 28, '09
From Austin, TX
This is one of our prototype kits that we used for R&D.
Here's the dyno run that we did. This was on the WG only on a totally stock Gen2 3sgte with only an exhaust, intercooler, and our turbo kit. With the addition of a boost controller to keep the WG shut longer you should be able to pick up a few hundred RPM worth of spool. This particular turbo will get you to around 400hp:
http://emspowered.com/productdevelopment/t..._gen2_17psi.jpg
First one with payment gets it. I need it outta here. $1200 shipped to anywhere in the US. I'll ship other places too, just PM me for shipping price to your place. Paypal by email or credit card over the phone.
The kit comes with everything needed for installation:
* Oil lines
* Fittings
* v-trim T3/T4 Borg Warner Turbo (similar power characteristics to the 46trim)
* Wastegate actuator
* Downpipe
* Gaskets
* Mounting hardware
* Silicone couplers
This comes with a steel turbine housing and a steel downpipe. The turbo was only used for about 50 miles. Basically to get to the dyno, do a few dyno pulls and then drive back. So it's basically almost brand new. This is for a Gen2 3sgte.
Here are a few pictures of the turbo and downpipe:
post May 5, 2009 - 6:58 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
AWESOME DEAL
330whp 309ft/lbs @ 21 PSI
post May 5, 2009 - 7:39 PM
wow, thats a lot of lag.
post May 5, 2009 - 7:43 PM
baktasht
Joined Jan 28, '09
From Austin, TX
QUOTE (lagos @ May 5, 2009 - 6:39 PM) *
Thats on the wastegate only without a boost controller so the wastegate is opening early. Add a boost controller to keep it shut longer and you'll gain around 300-400rpm of spool
Lo-Fi Version Time is now: August 31st, 2026 - 3:27 AM
