> More Problems... Oh yay... New Rims making my car drive horribley, :(
post May 18, 2009 - 7:42 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
Car kinda wobbles a bit at low speed and the wheel vibrates a small bit at 75+ MPH progressively getting worse until about 100, after having my rubber mounted and balanced i drove it and it was horrible, so i took it back and had them rebalance them, they showed me they were 0,0 (100% performance balanced) got back on the road and it continued.
Note: I use to run factory mags in horrible condition and my car ran smooth
frown.gif help
post May 18, 2009 - 7:52 PM
Nartanian
Joined Mar 26, '09
From Minnesota
QUOTE (Mstoochn @ May 18, 2009 - 8:42 PM) *
frown.gif help
Did you buy your rims used or brand new?
"God created turbo lag to give V8's a chance"
post May 18, 2009 - 8:13 PM
Mstoochn
Joined Apr 27, '09
QUOTE (Nartanian @ May 18, 2009 - 8:52 PM) *
frown.gif help
Brand new from a dealership
post May 18, 2009 - 9:29 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
OEM wheels?
Is the center bore of the wheel larger than the hub bore? (does the wheel's center fit perfectly on the hub?)
If it's larger you'll need to get some hub-centric rings to get rid of the vibration.
For example - My wheels have a center bore of 73mm. My hub is 56.1mm. So I have a hub-centric ring that brings the wheel hub from 73 down to 56.1
http://www.justforwheels.com/index.jsp?cat...ric&sub=how
**** Photobucket
post May 19, 2009 - 12:50 PM
Mstoochn
Joined Apr 27, '09
QUOTE (95CelicaST @ May 18, 2009 - 10:29 PM) *
OEM wheels?
they are RTX rims, and yes i am using hub centric rings 73-56.1mm.
post May 19, 2009 - 2:45 PM
95CelicaST
Joined Feb 5, '05
What size wheel and what size tire? Maybe you're just feeling more vibrations because you have less tire, you know?
**** Photobucket
post May 19, 2009 - 4:56 PM
Mstoochn
Joined Apr 27, '09
QUOTE (95CelicaST @ May 19, 2009 - 3:45 PM) *
same rim size as my factory mag's 15x6.5 same rubber 205/55/15 toyo proxy 4's
post May 19, 2009 - 8:49 PM
99Celica
Joined Nov 1, '07
From Santa Barbara, CA
Are the lug nuts torqued? rolleyes.gif Hey i've seen it happen
post May 19, 2009 - 9:33 PM
Mstoochn
Joined Apr 27, '09
QUOTE (99Celica @ May 19, 2009 - 9:49 PM) *
Yes, I even watched them do it and the guy gave me a dirty look so he made me do them myself tongue.gif got home and did it again for good measure
post May 20, 2009 - 2:53 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
alignment???
i have put so many rims on my car it isnt funny. kept borrowing rims, new and used, and i never got this "wobbling"
post May 20, 2009 - 9:39 AM
trdproven
Joined Aug 2, '05
From Guam
start from your lug nuts and work all the way into your suspension. could be anywhere between. first you must eliminate by feeling which side(s) its coming from.
you can balance a tire all you want if the tire is warped, lumped, feathered, etc there is nothing you can do but determine that first and replace.
This post has been edited by trdproven: May 20, 2009 - 9:41 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 20, 2009 - 11:01 AM
Mstoochn
Joined Apr 27, '09
QUOTE (trdproven @ May 20, 2009 - 10:39 AM) *
alignment was done, drive side front tire seems to be the issue. I would hope my proxy 4's aren't ****ed up, on my previous set of rims they wore evenly
Prior to installation of the new rims my car ran find, speeds of 120+ without any vibration, i dont believe suspension is an issue. Could the rim be ****ed?...
This post has been edited by Mstoochn: May 20, 2009 - 11:03 AM
post May 20, 2009 - 11:10 AM
95CelicaST
Joined Feb 5, '05
A warped rim, perhaps. Have the dealer mount your tires on another set and try again. If the vibrations are gone then it was a manufacturer defect in the rim(s).
**** Photobucket
post May 20, 2009 - 7:16 PM
trdproven
Joined Aug 2, '05
From Guam
find a rim or tire of similar spec or even just a test tire that is in known working condition, put that on, and compare the difference.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post May 20, 2009 - 7:39 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
the faster you go the less you'll feel.
Lo-Fi Version Time is now: May 20th, 2026 - 12:02 PM
