> Help with part numbers please
post May 30, 2009 - 2:46 AM
jeffrosie
Joined Sep 11, '08
From Surrey Unitedkingdom
Need some help please.
I need the part numbers for the bearing bracket that holds the longer driveshaft onto the E153 box. Pressure2 gave me the part# of the larger bracket 43457-20040 - thanks. I need the part# of the other half of this bracket - my Toyota dealer is not very helpful.
This is the last part keeping my car off the road.
This post has been edited by jeffrosie: May 30, 2009 - 2:47 AM
post May 30, 2009 - 7:38 AM
QUOTE (jeffrosie @ May 30, 2009 - 2:46 AM) *
jeff, for some reason, i dont think you specified that you needed the e153 carrier bracket, and i was not 100% sure what you meant by "other half" you do mean the bearing that is pressed onto the axle shaft?
just FYI, the axle is held in place in the carrier by a large c-clip.
i would go ahead and look at www.toyodiy.com and find the exact part you need.
looking here, you will need a few part #'s to get what you need.
http://www.toyodiy.com/parts/p_U_1991_TOYO...ZZA_4102.4.html
43457-17010 that is the e153 carrier bearing bracket
90521-78002 the snap ring that holds the bearing into the bracket
90369-41001 the bearing itself.
90520-38015 the snap ring for the bearing to shaft.
i would verify yourself that these are the parts you need before ordering anything else.
Lo-Fi Version Time is now: August 23rd, 2026 - 6:26 PM
