> Before i do it, any tips?
post Jul 12, 2009 - 9:43 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
Hey guys, God willing, I will be recieving the Crank pulley tomorrow from the brown bus. I will be replacing it and all, with the help of a buddy, I wanted to know if there was anything i should be aware of or know before doing it. any tips etc? its a pretty straight forward process, so hopefully it will go off without a hitch, im thinking about replacing the timing belt while im in there but idk.
any advice would be Greatly appreciated!
post Jul 12, 2009 - 10:08 PM
Look at me.... look at me.....
I'm proud of you!
just loosen/remove the alternator belt, then undo the crank bolt, and remove the pulley.
If you cant get the pulley off, you might need to go rent/buy a pulley puller.
post Jul 12, 2009 - 10:21 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
LOL! thanks lagos! thats means alot to me! biggrin.gif (told ya i would get my head outta my ass when i got a beater, AND my car back biggrin.gif)
ive been reading that its a PITA to get harmonic balancers off without it spinning... no power tools available, so breaker bar it is!
btw... should i be able to get my grubby hands on a proper air tool, what are the torque specifications to put it back on?
and if i cant get an air tool im thinking about bypassing extra muscle-->elbow grease-->puttin my back into it---> straight to ROID rage strenth! biggrin.gif
post Jul 12, 2009 - 11:45 PM
CelicaST_CALI
Joined Feb 28, '07
From Banland
i attempted to get mine off my 7afe to fix it and i couldn't(i didnt use a pully puller though)
The crank bolt broke loose without to much hassle,id just recommend getting a puller.Gl with it!!
BANNED. for life, you moron.
post Jul 12, 2009 - 11:55 PM
sometimes air tools cant get those things off.
a cool trick that people recommend is to put your socket on a breaker bar, and wedge the bar against the floor. then blip the starter (pull out your efi fuse so the car dont start) a few times and use the torque of the starter to get the bolt off.
post Jul 13, 2009 - 12:26 AM
Kwanza26
Joined Dec 27, '03
From Nor Cal
QUOTE (lagos @ Jul 13, 2009 - 5:55 AM) *
that is scary man. Just put it in gear.
post Jul 13, 2009 - 7:47 AM
QUOTE (Kwanza26 @ Jul 13, 2009 - 12:26 AM) *
"sounds" scary, but it works.
but, if you have a lightweight flywheel, with a bolted on ring gear, like the fidanza, you do not want to do that. the shock of doing it can round out the bolt holes and ruin the flywheel.
post Jul 13, 2009 - 2:48 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
imma try both! i just got the flywheel like 2 minutes ago from the brown bus!! i so happy! now its on to blood sweat and boost!
btw what should i torque it to when i put the bolt back on?
post Jul 13, 2009 - 2:55 PM
DEATH
Joined Dec 19, '07
From tx
QUOTE (lagos @ Jul 12, 2009 - 10:08 PM) *
I'm proud of you!
Get in there and get your hands dirty son! The only person that will give that girl the attn she deserves is her daddy laugh.gif
SUSP: Tein/Bilstein/SusTech/
EXT: WRC/TRD/404
Slow down Paul Walker.
post Jul 13, 2009 - 3:06 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
QUOTE (DEATH @ Jul 13, 2009 - 2:55 PM) *
I'm proud of you!
post Jul 13, 2009 - 3:07 PM
DEATH
Joined Dec 19, '07
From tx
good luck
EXT: WRC/TRD/404
post Jul 13, 2009 - 11:49 PM
easternpiro1
Joined Feb 1, '05
From Charlotte NC
great news!! SUCCESS!!! My homeboy buk gon helped me out, and everything runs great! timing belt was in good shape, but the power steering belt was average so i went and got a new one since we were down there. i used the breaker bar against the ground trick wink.gif but i didnt pull the EFI i just unplugged my coilpacks. came right off! now all i gotta do is go to a friends house and torque the bolt just to be safe!
and all is well in the jungle... for now... wink.gif DEFINATELY need to tune... car is beastly but seems like im hitting fuel cut @ certain rpms, will investiage further later.
This post has been edited by easternpiro1: Jul 13, 2009 - 11:50 PM
post Jul 14, 2009 - 7:28 AM
Lo-Fi Version Time is now: June 15th, 2026 - 8:32 PM
