Jul 17, 2009 - 1:01 PM
Enthusiast ![]() ![]() Joined Jan 27, '09 From New Orleans Currently Offline Reputation: 4 (100%) |
i have been wanting to get the fog lights for my ST but was wondering what would need to be done to have em wired up correctly and everytign
Jul 18, 2009 - 3:09 PM
anybody???
This post has been edited by NewOrleans: Jul 18, 2009 - 3:09 PM -------------------- ![]() |
Jul 20, 2009 - 1:10 AM
Enthusiast ![]() ![]() Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
mine already has the wires zip-tied inside, next to the radiator on both sides. It has never had fogs. Check yours.
Jul 20, 2009 - 7:08 AM
Enthusiast ![]() Joined Mar 14, '09 From Portishead Currently Offline Reputation: 0 (0%) |
In Europe teh standard models should already have fog lights fitted. I ran into this issue because a garage told me my model failed the MOT (roadworthiness test) due to absence of a fog light. However, he conned me because a car that does not have a fog light and does not have fog light controls, does not require a fog light, but if it has either the light or the controls, it should have the whole installation and it should be working properly.
This guy said I had fog lights but no control. Turns out that he just wanted to make a few pennies extra (because aswitch and wire costs next to nothing). He wired the one of the second brake lights as fog light, which screwed up the light-out indication circuit. So I fixed that but then was left without fog light. So I wired in a new fog light, which is quite easy to do: Get a fog light from some car accessory shop and mount it to the rear bumper (check your country's regulations on location of the fog light. In the UK that's between 30 and 50 cm above ground level and either right or at centre of the rear bumper). Run a wire to a switch in teh front (you need only one wire, the other you can connect to chassis directly from the lamp). Wire the switch to the high beam light (I think, because it will actually switch the fog light off when using high beam) via a fuse and you should be good to go. You can double check using the wiring schematics elsewhere on this site... |
Jul 22, 2009 - 12:00 AM
mine already has the wires zip-tied inside, next to the radiator on both sides. It has never had fogs. Check yours. Could you get some pics or a betterdescription because I looked and didn't see anything -------------------- ![]() |
Jul 22, 2009 - 12:09 AM
Yeah, ill see what i can do.. Im getting some brackets from asdbeard. Ill take pics when i get them and hook them up.
Jul 23, 2009 - 4:30 PM
ok
This post has been edited by NewOrleans: Jul 23, 2009 - 4:30 PM -------------------- ![]() |
Jul 23, 2009 - 9:29 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 2, '05 From Guam Currently Offline Reputation: 15 (100%) |
There were fogs for USDM 96-99 celicas so the factory harness or switch may possibly be already in place, you'll have to check. Now for the 94-95 USDM ones never came with fogs, you would have to wire it up manually. Either way if you don't find wiring for both you would have to do it yourself.
Jul 23, 2009 - 10:31 PM
Enthusiast ![]() ![]() Joined Mar 19, '09 From Malden, MA Currently Offline Reputation: 2 (100%) |
I actually have to wire fogs up soon. I see the connectors for them under the hood, but where is the other end of those wires? There is no fog light switch in my car.
Jul 24, 2009 - 11:10 AM
It might be like the integras where the other end of the harness is near the pedals and you still need the switch and relay. Look for those things first.
Jul 24, 2009 - 5:43 PM
well what im going to end up doing is running the power of fog lights off of one of the windows.
so that it will only get power when the car is on. and then i will put a switch inbetween power from windows to lights so i can turn them on and off as i please what do you think about that? -------------------- ![]() |
Jul 24, 2009 - 11:13 PM
You will blow a fuse. Definitely. There are plenty of spots on the fusebox for options you don't have (unless your celica is fullllllllly loaded) Just pull a new circuit.
| Lo-Fi Version | Time is now: June 28th, 2026 - 7:58 AM |
