Jul 18, 2009 - 6:49 AM
Enthusiast ![]() Joined Sep 6, '08 From Burlington Currently Offline Reputation: 0 (0%) |
Hey there all, I am in need of help. I am doing my brakes for the first time myself. I have run into a problem. The 4x14mm rear and 4x17mm front caliper bolts are seized for the caliper bracket are seized. I have tried rust check with a breaker bar, also an impact gun to get them off. But nothing worked. Only other idea i have is to heat them up and take them off. But not sure if that will work. Please let me know any other ideas you have please. Also, i am in need of the two back ones for the suspension. both bushings have ripped on me and i am swaying every now and again when i am on the highway. Please let me know where i can find those. Thanks all.
Jul 18, 2009 - 10:50 AM
Thats what had to be done to mine. All but one bolt came out fine. Had to torch it.
Jul 18, 2009 - 2:19 PM
Enthusiast ![]() ![]() ![]() Joined Apr 27, '09 From West Coast Canada Currently Offline Reputation: 0 (0%) |
impact gun should get it off bro, option 2 is heat it until its red and it will spin off easy
Jul 18, 2009 - 3:59 PM
you have settings on the impact gun. did you even attempt to shoot oil??? like wd-40??
the only way i can think atm is bang it, then use impact at the lowest setting and tighten the bolt a little, and then used the mid setting on the impact and try to loosen it. repeat when neccessary. This post has been edited by 808celica: Jul 18, 2009 - 4:00 PM -------------------- I don't normally drive fast, but when I do its on a curvy section of this island
Jul 18, 2009 - 11:59 PM
Enthusiast ![]() ![]() ![]() Joined Sep 19, '08 From Michigan Currently Offline Reputation: 4 (75%) |
Jul 19, 2009 - 5:13 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Apr 24, '08 From Orange County, CA Currently Offline Reputation: 33 (100%) |
the freezing spray can is pretty good stuff. good to know thats available for whenever i need it. thanks
-------------------- Group buy to replicate Narrow E series transaxle parts
http://www.6gc.net/forums/index.php?showto...p;#entry1107514 Items for Sale: http://www.6gc.net/forums/index.php?showto...p;#entry1107572 |
| Lo-Fi Version | Time is now: September 12th, 2026 - 12:31 AM |
