Aug 13, 2009 - 12:41 PM
Enthusiast ![]() ![]() Joined Nov 29, '07 From Colorado Currently Offline Reputation: 4 (100%) |
I've got the 8 speaker sound system in my Celica, with the premium headunit.
The tape player will occasionally click when I'm listening to my iPhone, which is really annoying.(It's very loud.) Is there a fix? Something I can do? I refuse to buy another headunit(unless it's another OEM one identical to what I have(and if you want to sell yours, PM me, I want a spare)) because I don't want a disco ball in my cockpit. Thanks! -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Aug 13, 2009 - 1:00 PM
Enthusiast ![]() ![]() Joined Apr 20, '09 Currently Offline Reputation: 4 (100%) |
I've got the 8 speaker sound system in my Celica, with the premium headunit. The tape player will occasionally click when I'm listening to my iPhone, which is really annoying.(It's very loud.) Is there a fix? Something I can do? I refuse to buy another headunit(unless it's another OEM one identical to what I have(and if you want to sell yours, PM me, I want a spare)) because I don't want a disco ball in my cockpit. Thanks! Define clicking? Are you using a tape-deck adapter? One that goes into your tape-deck with a wire that comes out of the front and runs to your iPhone's 1/8" Jack? If so... I feel as if you're talking about the tape-deck's mechanical noise. You'll also hear some god-awful tape-hiss from that through the speakers. There's nothing you can do unless you want to modify your stock CD-Player (if you have one) and add in a 1/8" AUX-In (like me, removes all CD-Player functionality unless you design a switching circuit to switch from the AUX/CD Input) or get a new head-unit. Take your pick. -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Aug 13, 2009 - 1:22 PM
2Hz loud mechanical clicking coming from the deck. I use a 1/8 to Tape adapter.
It only clicks sometimes. Unfortunately, everything's integrated, so I guess I could go sniffing traces on the radio... -------------------- 2019 M2, 2005 S2000, 1997 4Runne
Aug 13, 2009 - 1:56 PM
2Hz loud mechanical clicking coming from the deck. I use a 1/8 to Tape adapter. It only clicks sometimes. Unfortunately, everything's integrated, so I guess I could go sniffing traces on the radio... As long as that tape is in the deck, it will click. I've never seen a tape-deck that doesn't make that sound. What do you mean "everything's integrated?" There's no built-in AUX-In in the stock head-unit, you'll need to tap into the amplifier's line-in by sniffing traces. However, you'd have to use the radio's input, not the tape-deck's. If you tap into the tape-deck's output to the amp, then you'll still get clicking, just no tape-hiss. Either way, you'll render whatever you tap into useless unless you build yourself a switching circuit. -------------------- ~Moving on to a 2002 Corolla S~ R.I.P Tom Celica - 1994-2010 |
Sep 4, 2009 - 4:02 PM
Enthusiast Joined Aug 26, '09 From north hollywood Currently Offline Reputation: 0 (0%) |
you need to press the 1 2 3 4 5 6 one of those and then itll stop clicking
i had the same problem. ou just need to set a program to play your cassette on. |
Sep 4, 2009 - 4:20 PM
Enthusiast ![]() ![]() ![]() Joined Mar 22, '07 From Murphy, TX Currently Offline Reputation: 5 (100%) |
wow a tape player --Its been so long since I used one of those things.
Nov 25, 2009 - 1:51 PM
Enthusiast ![]() Joined Apr 27, '08 From Michigan Currently Offline Reputation: 0 (0%) |
Ah, you not going to want to hear this, but here goes: I also have the premium sound w/cassette and this is what I found: the drive gears develop cracks, see pic below, probably due to heat/cold cycles. The areas outlined in hot pink are where they are on mine, as you can see I tried re-shaping the gears and gluing them a bit but it only helped when playing in one direction.
I spent a couple hours trying to find info on the net for Fujitsu parts but didn't have much luck. As a side note the Mrs's Camry (2000 LE) makes the same noise on her cassette, so I expect it is the same unit. When I figur' out how to post an image w/o using p'bucket you'll see what I mean. This post has been edited by TerryE: Nov 25, 2009 - 4:31 PM |
Nov 25, 2009 - 4:46 PM
Any help uploading images to a post???
This post has been edited by TerryE: Nov 25, 2009 - 5:42 PM |
Nov 25, 2009 - 6:08 PM
Nov 25, 2009 - 6:51 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Oct 7, '09 From Northern kentucky Currently Offline Reputation: 8 (90%) |
your best off just buying a new head unit and just replacing the old one, its really easy to do
Nov 25, 2009 - 8:58 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
terry that happened to me...i just changed the headunit...have u tried different tapes?
Nov 26, 2009 - 9:45 AM
terry that happened to me...i just changed the headunit...have u tried different tapes? I'd replace it if I could but no work no money (michigan) 'sides I already took it apart and saw where the gears split/cracked. Totally p/p design, molding nylon around a metal disc. I don't think they ever thought about thermal expanxion contraction effects, (amazing because the Fujitsu Ten units in my older Toyota's '90 ST and '77 GT were -bulletproof.) |
Nov 26, 2009 - 10:11 AM
Ah, maybe th pic will come thru now:
![]() The pink circled areas are the cracks, notice the shine from my attempt at using super glue to reconnect the halves of the gears (helped), also note the re-shaping of the gears with a swiss file (which did'nt work due to gears being nylon or delrin), ended up using an x-acto knife which did help (barely audible) in one direction only. Anybody know where to get Fujitsu Ten parts? |
| Lo-Fi Version | Time is now: June 21st, 2026 - 8:08 AM |
