> Shifting prob.., 2nd
post Aug 17, 2009 - 4:01 PM
cibrit-
Joined Sep 16, '08
From Michigan
Hey guys,
Every time I go from 1st to second gear, if I don't ease it in real slow than it will grind... Usually if I'm up to or higher than 3k RPMs in first and shift, it will grind regardless. All the other gears go in real easy, and as fast as I can put them in.
Does anyone have a reason for me as to why this might be happening?
94' Red Celica ST Hatchback: 3S-GTE Swap
Upgrade??: ATS CT27 Kits
-Toni
post Aug 17, 2009 - 4:10 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Sounds like your 2nd gear synchro is on it's way out. Rebuild time!
**** Photobucket
post Aug 18, 2009 - 3:05 PM
cibrit-
Joined Sep 16, '08
From Michigan
UGH, new tranny time! ahha.
I heard that using synchromesh on some cars helps the transmission a lot. Is this good for our cars? Well, my 3sgte..
-Toni
post Aug 18, 2009 - 3:37 PM
AMCMoe
Joined Nov 20, '04
From Carlisle, PA
It does help but its not going to be a night and day difference. I've used Pennzoil Synchromesh in 5 or 6 vehicles I've had in the past and generally do like it, however I'd say it's more so dependent on the condition of the transmission and when the gear oil was last changed than the brand of oil used... For $25-30 bucks, it may be worth it as temporary fix, if nothing more than a bandaid.
Call a transmission shop in your area and ask them how much it would be to replace the synchro(s). Also, if you can take the transmission out of your Celica, it'll be much cheaper. You say it shifts into the other gears very easily, so to me it sounds like it'd be money more wisely spent than finding another transmission and having....3rd gear not shift smoothly.
post Aug 27, 2009 - 8:41 PM
Raves44
Joined Mar 26, '09
From Colorado Springs
well actually my car does the same thing mostly 2nd and 3rd so a good way to check if it is the tranny would be to rmp match it when you shift without using the clutch we did this with my car and we are 90% sure its actually the clutch we think the pressure plate is collapsing so maybe just something to check into.
post Aug 28, 2009 - 11:06 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (Raves44 @ Aug 27, 2009 - 8:41 PM) *
I'm not a genius at this stuff, but if it was the clutch wouldn't it be grinding on all gears????
Lo-Fi Version Time is now: July 30th, 2026 - 6:02 PM
