> Quick Oil Pan Question
post Oct 28, 2009 - 3:12 PM
6G96GT
Joined Jan 20, '08
From East Coast
I had my oil pan gasket replaced today. The mechanic said when he pulled the pan down, he noticed the screen had some sludge on it but he cleaned it off and it's good to go. My question is this...the pan gasket should be fine right? I mean it's a straight forward simple job for a mech to do right?
Also, If the oil is over the full mark 1/2 a quart, how bad is that for my car, should I even be worried at all about that? When they re-installed the pan, they obviously did a fresh oil change and added 4.5 quarts (.3 over the actual limit) and I don't think they considered the oil filter and the oil it retained (they left the filter on and didn't change it since it was fairly new).
This post has been edited by 6G96GT: Oct 28, 2009 - 3:26 PM
post Oct 28, 2009 - 6:54 PM
.3-.5qt over won't really hurt anything
you're asking us if we think your mechanic can change a pan gasket? if you have to ask us that then you should get a new mechanic.
post Oct 29, 2009 - 3:38 PM
6G96GT
Joined Jan 20, '08
From East Coast
It's not that I doubt him, I guess it's more along the lines of an oil pan gasket job. Is it a job that is a simple job or is it one that 'usually' comes with problems...sort of like how there's a lot of talk about servicing transmissions...before they're serviced, they're fine and then once they are serviced, they go to hell. Ever hear that?
post Oct 29, 2009 - 7:00 PM
the transmission thing is like this...
people lie. they're in denial, their trans is already acting goofy so they go in for a flush and then 'ever since' its acting goofy. thats what happens, or the guy doing the service uses the wrong fluid. its pretty hard to **** this up, i've done plenty of them. new fluid in, old fluid out, simple as that. don't run it dry, dont overfill it, and use the correct fluid.
as for the oil pan, it takes about an hour and a half, then 24hrs for the silicone to setup.*
*if the exhaust comes down OK, no studs or bolts break, may need to replace the exhaust gaskets as well.
post Oct 29, 2009 - 9:33 PM
6G96GT
Joined Jan 20, '08
From East Coast
good to know. Thanks Bitter.
Lo-Fi Version Time is now: August 22nd, 2026 - 10:36 AM
