> troubleshooting Power windows problem, passenger power window not working
post Oct 29, 2009 - 3:03 PM
nta3392
Joined Oct 7, '09
From indianapolis
hi, how do i trouble shoot the power window ,
even though i don't think is related , i was working on the radio, and took off the previous radio and installed a new one.
after that , the next morning the passenger side power windows doesn't roll down, although the driver's side does work.
what can i do to find the problem and then fix it?
any help and links would be appreciated!!
post Oct 29, 2009 - 3:08 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
QUOTE (nta3392 @ Oct 29, 2009 - 3:03 PM) *
...this has happened to me... check ur window lock... good chance you accidentally bumped it or something and locked it.. GL
post Oct 29, 2009 - 3:31 PM
nta3392
Joined Oct 7, '09
From indianapolis
QUOTE (bseaman_5 @ Oct 29, 2009 - 3:08 PM) *
where is it at? my window still rolls down thou?
post Oct 29, 2009 - 6:53 PM
Keiri
Joined Mar 6, '04
From Charlotte, NC
QUOTE (nta3392 @ Oct 29, 2009 - 4:31 PM) *
It's right next to the power window down/up button; just above the passenger side window up/down toggle.
Has no more Celicas
post Oct 29, 2009 - 7:46 PM
nta3392
Joined Oct 7, '09
From indianapolis
thanks!!! this thas had to be the easiest fix ever lol!!!
post Oct 29, 2009 - 8:32 PM
bseaman_5
Joined Apr 6, '08
From Overland Park
yeah... I did too.. ha ha its all good tho
post Oct 29, 2009 - 10:45 PM
azian_advanced
Joined Apr 18, '05
From Calgary
and i think there has been two similar threads in the past... so you're not the only one. lol biggrin.gif
post Nov 24, 2009 - 1:22 AM
mono8477
Joined Jul 7, '08
From California
QUOTE (nta3392 @ Oct 29, 2009 - 12:03 PM) *
This is the same problem I'm dealing with right now. The issue with mine is that it is the rear passenger side window. I had a friend pull out my radio and I'm not sure if this is related, but my window doesn't work anymore. So... I tore it apart and now have the window power motor out. At this point everything that I've troubled shot leads me to believe that that my motor is no longer working. The cheapest but riskiest route for a replacement, is buying one a wrecking yard. So good luck with your trials. I'll keep you posted on my endeavors!
Lo-Fi Version Time is now: June 16th, 2026 - 10:27 AM
