> Quick Question!, Air intake.
post Nov 4, 2009 - 3:22 AM
MrAyasli
Joined Aug 19, '09
From Sydney
Would this fit my Celica SX 2.2L?
or would I need a different one?
http://cgi.ebay.com/ebaymotors/1995-1996-1...sQ5fAccessories
and if you suggest a different type of intake (better one) let me know.
Thanks !
post Nov 4, 2009 - 7:25 AM
Euphoria
Joined May 6, '08
From Lisarow, NSW, Australia
well it says 2.2 but the pic is off a ST celica, I don't see why It wouldn't, you can also buy proper cold air intakes on ebay.
post Nov 4, 2009 - 7:44 AM
whatthe
Joined Aug 13, '08
From Australia
It will work.
post Nov 4, 2009 - 11:56 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
it will work and it sounds good, all of the 6th gen us models have the same intake manifold, some of them just do not have the breather tube like mine, but they are nice and only take about 5 minutes from start to finish, and it gives a pretty good sound along with a few hp increase, i love the way mine sounds
2001 Solar yellow Lexus IS300
post Nov 4, 2009 - 2:47 PM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
QUOTE (96stgreendemon @ Nov 4, 2009 - 8:56 AM) *
Incorrect. The 7A and the 5S do NOT share the same intake manifold.
**** Photobucket
post Nov 4, 2009 - 9:14 PM
96stgreendemon
Joined Oct 7, '09
ok then let me rephrase this, they have the same inlet for the intake to adapt to and the same MAF sensor, the intake will fit
post Nov 4, 2009 - 10:10 PM
nics
Joined Feb 15, '08
From Royal Oak, MI
God made man....
Everything else...
Made in China
post Nov 4, 2009 - 10:54 PM
delusionz
Joined Feb 11, '08
From Auckland, New Zealand
You have the 5S-FE which has a 2.5" throttlebody.
Basically you need a 3" Intake pipe (any will do, aslong as its free of loose shavings and is smooth)
2.5" to 3" reducer coupler
2 clamps for the coupler - 2.5" and 3"
An additional 3" clamp for the air filter
And an air filter - I recommend K&N Pod filter or HKS Mushroom Filter but any will do.
If the pipe has a 10mm nipple on it you can connect the existing oil breather pipe, Otherwise put a Minifilter on the end of the oil breather hose.
PS: that minifilter on the side of that intake pipe doesn't need to be there. A simple vacuum cap will do.
Mike W
269awhp / 273ft-lbs
post Nov 5, 2009 - 10:53 AM
96stgreendemon
Joined Oct 7, '09
MAF is mass airflow sensor
post Nov 6, 2009 - 12:01 AM
delusionz
Joined Feb 11, '08
QUOTE (96stgreendemon @ Nov 6, 2009 - 4:53 AM) *
Not applicable to any Gen6 engine.
Mike W
269awhp / 273ft-lbs
post Nov 6, 2009 - 12:09 AM
Rusty
Joined Nov 5, '07
From New Zealand
SS-II/III BEAMS engines are MAF/AFM (A MAF (Mass Air Flow) or AFM (Air Flow Meter) measure the mass or volume of air.)
post Nov 6, 2009 - 12:33 AM
delusionz
Joined Feb 11, '08
Woops, Forgot about the Beams.
Mike W
269awhp / 273ft-lbs
nics
Joined Feb 15, '08
From Royal Oak, MI
QUOTE (96stgreendemon @ Nov 5, 2009 - 7:53 AM) *
i know what it stands for, just not sure if 5s has it but now i know beams has it.
This post has been edited by nics: Nov 6, 2009 - 12:35 AM
God made man....
Everything else...
Made in China
post Nov 6, 2009 - 12:34 AM
delusionz
Joined Feb 11, '08
Beams is the one engine I have never experienced in a Celica, Although it's pretty nice in an Altezza RS200 tongue.gif (If it wasn't such a heavy car)
Mike W
269awhp / 273ft-lbs
post Nov 6, 2009 - 2:12 AM
MrAyasli
Joined Aug 19, '09
From Sydney
Well guys I've just purchased this item and waiting for the payment to clear.
post Nov 7, 2009 - 3:09 PM
benzo
Joined Jul 23, '09
From Fresno, Ca
QUOTE (MrAyasli @ Nov 6, 2009 - 2:12 AM) *
i don't have that exact intake, but im telling you, once you take it for a drive you'll get a fat grin on your face smile.gif
post Nov 18, 2009 - 9:45 AM
Cs91
Joined Oct 16, '09
From Norway
QUOTE (benzo @ Nov 7, 2009 - 4:09 PM) *
I got it, and can confirm this smile.gif Sound is so nice, and if giving it some while idling it will sometimes sound as if u got a tiny blow off valve;)
post Nov 18, 2009 - 10:07 AM
CastrolCelica
Joined Sep 27, '09
From Columbus, Ohio
QUOTE (Cs91 @ Nov 18, 2009 - 10:45 AM) *
post Nov 18, 2009 - 10:39 AM
96stgreendemon
Joined Oct 7, '09
yea i can agree with the big fat grin, just hit the gas when your drivign in an underpass, i love it, its almost as loud as an exhaust, i love mine and would never put the stock back on
post Nov 18, 2009 - 12:22 PM
CastrolCelica
Joined Sep 27, '09
From Columbus, Ohio
QUOTE (96stgreendemon @ Nov 18, 2009 - 10:39 AM) *
Filter boxes don't make any sense. All they do is rob you of power and make you come back in to get serviced every time you need a new filter............ok now it makes sense. Greedy bastards. laugh.gif
Lo-Fi Version Time is now: August 25th, 2026 - 9:16 AM
