> code 52 code 51 all new parts
post Nov 13, 2009 - 8:50 PM
mk7celica
Joined Feb 2, '09
From new orleans La.
I had the car running fine then I pop a code 52. So I change the ks to a ast sensor kit. Still code 52. So I change the wire to the ecu from ks still code 52. ThenI pull the ecu and fine a burnt spot on a board so I replace the ecu with a blitz ecu. Still code 52 an now with the new ecu I pull a code 51.here is a video of the cel coming on after restting the ecu. It dont come on untill 2000 rpms. Car is in limp/safe mode because of this. I am not sure if the new ecu is faulty. I checked the ks wire again an it looks fine so I am out of ideas. Heres a video
http://s640.photobucket.com/albums/uu123/m...nt=carvideo.flv
post Nov 13, 2009 - 10:06 PM
Mstoochn
Joined Apr 27, '09
From West Coast Canada
QUOTE (mk7celica @ Nov 13, 2009 - 8:50 PM) *
doesn't seem like its a wiring/electrical issue. do u have a video with good sound of the engine? can u hear a knock at idle?
post Nov 13, 2009 - 10:53 PM
urbandork
Joined Jul 16, '04
From Los Angeles
what gen 3sgte r u running
This post has been edited by urbandork: Nov 13, 2009 - 10:54 PM
post Nov 15, 2009 - 8:27 PM
mk7celica
Joined Feb 2, '09
No knock I can hear and its a gen 2
post Nov 16, 2009 - 1:15 PM
urbandork
Joined Jul 16, '04
From Los Angeles
QUOTE (mk7celica @ Nov 15, 2009 - 5:27 PM) *
what was burnt on the ecu board... was it a resistor? and if so what pin was it correlated with.
i had a similar problem with a 54 cel (w2a intercooler related) and found that i burnt out the resistor because it had not been hooked up to a relay correctly.
the knock sensor can also pick up vibes/knocks before you can even hear it.
This post has been edited by urbandork: Nov 16, 2009 - 1:16 PM
Lo-Fi Version Time is now: September 4th, 2026 - 6:47 PM
