> ABS Code, Have to be sure
post Nov 25, 2009 - 2:17 PM
Davis_2
Joined Sep 8, '08
From Ireland
Code 35
Open in left front or right rear wheel speed sensor circuit.
Check speed sensor, sensor rotor, wiring harness and connector.
got code 35 after bridging on a 97 celica st205 if it makes a difference. by the way thanks to all 6gc members you's have sorted out a fair few things for me. Back to the situation got the above got now night time over her so not able to check this just means there is a space between either sensor or not connected properly at connection point please correct me if im wrong.
This post has been edited by Davis_2: Nov 25, 2009 - 2:18 PM
post Nov 25, 2009 - 2:31 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Or the wire is broke.
post Nov 25, 2009 - 2:40 PM
Davis_2
Joined Sep 8, '08
From Ireland
QUOTE (Spider77 @ Nov 25, 2009 - 2:31 PM) *
Any way on knowing exactly which one is gone or causing the problem.
post Nov 25, 2009 - 3:35 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Well, Im looking at my book, and there is no code 35 for that (31 - 34 though, one code per speed sensor circuit). First thing to check for is to see if the sensor came loose. If they are still clipped in, then do some resistance checks. Resistance for the front on terminals 1/2 should be 1-2.6Kohms, and resistance of terminals 1/2 of speed sensor connector to ground should be 1Mohm or higher. For the rear the numbers are .8-2.1Kohm, and 1Mohm or higher. If you obviously get infinity, then you know where your problem lies.
If everything checks out, then you could check for the open between your ecu and speed sensor.
Third thing you can do is check the speed sensor rotor its self, look for missing teeth/scratches, and that the installation bolt is secured.
All in all, its probably a loose/corroded connection. Im not too sure what the code would be, but it might be a fuse as well (blown fuse would cause and open condition)
Im sure that you might know, but an open in a circuit is pretty much what it sounds like. A point in a circuit that does not allow current to flow. Kind of like a light switch, switch off, disrupts the current, switch on, completes the circuit and allows current to go.
This post has been edited by Spider77: Nov 25, 2009 - 3:42 PM
post Nov 25, 2009 - 3:45 PM
Davis_2
Joined Sep 8, '08
From Ireland
QUOTE (Spider77 @ Nov 25, 2009 - 3:35 PM) *
I got the code by bridging the terminals. Will go through that this week end. apart from a scanner cause can't find or don't know if i have an obd2 port
post Nov 25, 2009 - 3:52 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Being tht I have a 94, I never bothered to learn where the hook up is for OBDII.
post Nov 25, 2009 - 6:04 PM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
QUOTE (Spider77 @ Nov 25, 2009 - 10:52 AM) *
near your right leg in the cockpit
post Nov 25, 2009 - 6:59 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Hahahah...cockpit. OK, sorry had a bit. Hopefully it is just loose/corroded connectors. G/L!
post Nov 28, 2009 - 6:08 PM
Davis_2
Joined Sep 8, '08
From Ireland
Bridged again a few days back got code 31 and 35 so good bit of checking to do.
post Dec 12, 2009 - 7:00 AM
Davis_2
Joined Sep 8, '08
From Ireland
Ok must be the wrong codes for my car as the sensor gone was the front right one ah sure no harm just check the oms on all them the one with no reading got change and now all good. Thanks again Lads
post Dec 12, 2009 - 9:36 AM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Good to hear it was just a sensor and didnt require any more digging in than required!
Lo-Fi Version Time is now: September 11th, 2026 - 6:12 PM
