Jan 3, 2010 - 1:59 PM
Enthusiast ![]() ![]() ![]() Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) |
Okay so i was getting ready to put my fenders back on and realized all the bolts were snapped that originally held them in place, only 2 aren't broken. . any suggestions as to how i can get this problem solved?
there are like 2 on the top of each sides that are busted off, and the bottom ones are also busted off inside the holes. let me know asap as i'd like to get my car finished soon. thanks -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
Jan 3, 2010 - 2:27 PM
Enthusiast ![]() ![]() Joined Jan 17, '09 From Hilo Hawaii Currently Offline Reputation: 0 (0%) |
http://lmgtfy.com/?q=how+to+remove+a+broken+bolt
i normally go to google for common problems. best of luck man |
Jan 3, 2010 - 2:28 PM
Enthusiast ![]() ![]() ![]() Joined Jul 13, '09 Currently Offline Reputation: 9 (91%) |
Okay so i was getting ready to put my fenders back on and realized all the bolts were snapped that originally held them in place, only 2 aren't broken. . any suggestions as to how i can get this problem solved? there are like 2 on the top of each sides that are busted off, and the bottom ones are also busted off inside the holes. let me know asap as i'd like to get my car finished soon. thanks i had this problem and there is two ways of fixing it, the right way and the fast way, i picked the fast way and i'm going to go back and do it right one day..... the right way..... go to home depot and buy a tap and dye kit, drill out said bolts and use the kit to re-thread the holes and then reinstall the fenders as usual. the fast way.... go to home depot and buy some inch and a quarter self tapping metal screws, put the fender one in the correct place so that all the lines are correct and use said screws to replace broken bolts about an inch and a half from the original holes. like i said the fast way works and the only way anyone can tell is when they open the hood and see the screws but the right way produces the factory look, good luck to you on this one. -------------------- You're here for a good time, not a long time. - Colin McRae When in doubt... Flat out! - Colin McRae Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.... |
Enthusiast ![]() ![]() Joined Oct 23, '08 Currently Offline Reputation: 24 (100%) |
you could try to find a left handed drill bit it will act like an easy out and the heat from drilling should help loosen the bolt. otherwise just use a regular drillbit and tap the holes. did you get my pm about the gt?
Jan 3, 2010 - 3:44 PM
Extractor Have these at the shop, work wonders. Also a tap and dye kit is handy to have around in case you strip something out.
| Lo-Fi Version | Time is now: September 8th, 2026 - 2:06 PM |
