Jan 7, 2010 - 11:56 AM
Enthusiast ![]() Joined Mar 10, '08 From Ct Currently Offline Reputation: 0 (0%) |
i got a bone stock 5sfe with piston slap now ....
Jan 7, 2010 - 12:16 PM
Swap. (Even if it's another 5SFE - it'll probably be easier & cheaper.)
This post has been edited by Supersprynt: Jan 7, 2010 - 12:16 PM -------------------- |
Jan 7, 2010 - 1:19 PM
Swap. (Even if it's another 5SFE - it'll probably be easier & cheaper.) thats the thing lol. i am looking for the small budget route, i dont have much money to play with. and the reason i wanna stay with the same motor is because its practicly brand new ( head, crank, bearings, oil & water pump ). so all i wanna do is just get my cylinders redone with right size pistons. just wanna know if it would be ok to redo my cylinders or just get a used block |
Jan 7, 2010 - 1:36 PM
I'm not sure where you're going to find new pistons on the cheap for it. A used short block will be a couple hundred.
http://cgi.ebay.com/ebaymotors/TOYOTA-90-9...sQ5fAccessories This post has been edited by Supersprynt: Jan 7, 2010 - 1:37 PM -------------------- |
Jan 7, 2010 - 7:33 PM
Enthusiast ![]() Joined Nov 27, '09 From New York USA Currently Offline Reputation: 5 (100%) |
Swap. (Even if it's another 5SFE - it'll probably be easier & cheaper.) thats the thing lol. i am looking for the small budget route, i dont have much money to play with. and the reason i wanna stay with the same motor is because its practicly brand new ( head, crank, bearings, oil & water pump ). so all i wanna do is just get my cylinders redone with right size pistons. just wanna know if it would be ok to redo my cylinders or just get a used block You can transfer the head, water pump and any other external goodies to the new block. Bearing and oil has to be replaced any way. I think it would be safer and a lot cheaper to get a used block. When ever there is a piston replaced there is a posibility of problems either compression related or smoke burning. Unles you find somebody who really knows how to do this but then you are looking at a lot of $ for labor. Good luck with what ever you decide... |
Jan 7, 2010 - 8:21 PM
thats what i wanted to do but i am having trouble finding a block. and i would bring it to a machine shop to get it done right, luckly i have a friend that said he would do it for a pretty good price so im not worried there.
And smoking is exactly what my motors doing now, thats why i want a new block. its rather embarrasing so i guess im just getting a new block, no one has said to stick with the one i got lol. so thank you |
Jan 8, 2010 - 11:35 AM
why are you getting slap in the first place. was this engine opened up? and how do you know its piston slap. did you look into the cylinders with a bore scope and see scratched on the walls.
Jan 8, 2010 - 4:18 PM
why are you getting slap in the first place. was this engine opened up? and how do you know its piston slap. did you look into the cylinders with a bore scope and see scratched on the walls. i dont know what exactly went wrong but when i replaced my head thinking thats what my oil burning problem was i noticed my pistons had some wiggle room. |
Jan 12, 2010 - 7:05 PM
![]() Enthusiast ![]() ![]() ![]() Joined Feb 10, '06 From Knoxville, TN Currently Offline Reputation: 8 (100%) |
Anyone know what a bare block weighs? I have one but I need to get a shipping estimate.
Jan 13, 2010 - 12:57 PM
bare block = heavy! i bet its close to 100lbs
Jan 13, 2010 - 1:14 PM
thats about as far as i got lol. closest thing i found was that its 125lbs with the crank. anyone know how much a crank weighs
| Lo-Fi Version | Time is now: July 29th, 2026 - 5:50 AM |
