Nov 4, 2003 - 12:03 PM
Enthusiast ![]() Joined Oct 12, '03 From richland, wa Currently Offline Reputation: 0 (0%) |
Nov 4, 2003 - 1:04 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From Anaheim, CA Currently Offline Reputation: 0 (0%) |
you will need more than $1500 to do all that work.
stock a 7afte setup will hold 10psi with no reliability problems and not too much of a shorter life. expect to spend $600-$700 for custom rods then $500 for pistons get a custom regrind on the cams, port and polish, custom valves. i would guess you should be ready to spend about $2500 on a performance rebuild. make it a turbo motor, and you should make a lot of power. a 7afe with a t3/t04 turbo with stock internals, fmic, and stock injectors made 160whp. i would say you could run upwards of 17psi daily if you replace the internals. -------------------- 1994 Celica GT4 WRC Edition
@gt4.wrc on Instagram |
Nov 4, 2003 - 3:00 PM
If I wanted 160 I'd go buy something with an H on the valve cover. I'm having the engine machined for free and can get great deals on whatever else I need. Without a turbo, what can i do to rebuild the motor to get it closer to 200 HP mark naturally.
Nov 4, 2003 - 6:33 PM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 21, '02 From Italy Currently Offline Reputation: 0 (0%) |
Everything u can do....I mean:
BLOCK Custom titanium rods (lightest) Crank knife-edged and balanced Custom forged pistons with at least 12:1 CR If u have $$$$ custom rods,crank,pistons to become a 2.0 liter HEAD Complete P&P Custom oversized valves titanium springs and retaiers Regrounded cams (or custom) A good Metal Head Gasket IGNITION Digital system (like MSD) Powerful Coil (MSD) 8.5mm wires Iridium colder sparks INJECTION Upgraded injectors Upgraded fuel pump Adjustable FPR INTAKE Good CAI bored TB or better 4Throttle from 4AGE or bigger EXHAUST Header (4-2-1 for low-middle power(Arospeed,OBX) or 4-1 for top end power(custom)) Full Cat-back exhaust ELECTRONIC Standalone ECU or Piggyback like SAFC or Emanage POWER TO THE WHEELS ASP underdrive pulley OBX accessory pulleys OBX cam gear Lightweight Flywheel Stage 2 or 3 clutch LSD With this setup u can reach high HP output for a N/A engine like our This post has been edited by edo17982: Nov 4, 2003 - 6:34 PM |
Nov 4, 2003 - 8:48 PM
oh do what Edo listed. he pretty much covered everything you could do to the engine and still keep is NA with all the stuff he listed im pretty sure it will give some good, reliable power. i personally went for a turbo setup with stock internals. once i get a FMIC and a fuel pump/injectors i will be good to probably 200whp. that would be just about all i would want with a fwd car, lol. -------------------- 1994 Celica GT4 WRC Edition
Nov 5, 2003 - 1:35 AM
![]() Enthusiast ![]() ![]() Joined Sep 6, '03 From Fairbanks AK Currently Offline Reputation: 0 (0%) |
http://www.6gc.net/forums/index.php?showto...t=0entry68445
that should give you an idea of what you can get out of a 7A edit: scroll to top This post has been edited by van95st: Nov 5, 2003 - 1:35 AM |
Nov 5, 2003 - 5:30 PM
Cool idea's for the engine and naturally aspirited setup. The intake and air induction and ignition ideas are simple. I just want internal ideas and I'll worry about that junk later. If I can do internals to get me over 160 I'll be happy.
Nov 5, 2003 - 5:47 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Aug 30, '02 From San Juan, PR Currently Offline Reputation: 4 (100%) |
Ha, ya'll see a 200 whp automatic tranny STOCK eveything Celica soon...I already found a bad-ass tuner back home...my tuning is going to be so precise...that I'll burn the tranny, hahaha, but I'll swap a manual one when that one dies
Nov 6, 2003 - 10:29 AM
Enthusiast ![]() ![]() ![]() Joined Sep 9, '02 From Scranton, Pa Currently Offline Reputation: 7 (100%) |
Nov 6, 2003 - 11:25 AM
Nov 6, 2003 - 11:26 AM
I think I'm just going to settle for the fact that the Celica is a nice looking car... and well it costs way too much money to do anything with it. I'm just gonna get the MKII MR2 like I should have in the first place. =)
Nov 6, 2003 - 1:57 PM
my parents would let me get one when i was looking to buy. |
| Lo-Fi Version | Time is now: June 23rd, 2026 - 11:32 PM |
