Jan 16, 2010 - 5:09 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 16, '09 From New York Currently Offline Reputation: 23 (100%) |
I know my old bumper was a prelift so the clears wouldt fit right, but now that i have a VIS invader kit, could i get the clears ive always wanted?
thanks- -------------------- |
Jan 16, 2010 - 7:34 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 22, '04 From FL Currently Offline Reputation: 1 (100%) |
parts are interchangeable. If you are installing headlights you will have to remove the bumper. If you are doing side marker lights and IF you have custom fenders (ie z3, laser etc)then you can put that clear marker in the hole. If you dont have a hole then you would have to obviously cut it.
-------------------- Captain Pessimist
Jan 17, 2010 - 3:08 AM
Im not installing headlights? or side markers
heres a pic, i want to change the front blinkers/turn signals to clear once i put the FB of the bodykit on, can i do that? ![]() parts are interchangeable. If you are installing headlights you will have to remove the bumper. If you are doing side marker lights and IF you have custom fenders (ie z3, laser etc)then you can put that clear marker in the hole. If you dont have a hole then you would have to obviously cut it. -------------------- |
Jan 18, 2010 - 4:15 PM
Enthusiast ![]() ![]() ![]() Joined Jul 13, '09 Currently Offline Reputation: 9 (91%) |
look at mine, i had to cut the bumper a touch to mount correctly but the facelift side lights/blinkers fit great....i'll take close up pics as soon as it stops raining...
here is a pic...
This post has been edited by ajmorris1977: Jan 18, 2010 - 5:10 PM -------------------- You're here for a good time, not a long time. - Colin McRae When in doubt... Flat out! - Colin McRae Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.... |
Jan 18, 2010 - 10:42 PM
Cool thanks, cant wait to get the clears, hate! the amber color ones, they look too stock.
Also do you know where to get like the wire mesh? that goes behind the blinkers and can it go in the front too? thanks- my kit didnt come with it in the front, only small rear mesh pieces? and is it expensive? thanks -------------------- |
Jan 18, 2010 - 10:59 PM
Cool thanks, cant wait to get the clears, hate! the amber color ones, they look too stock. Also do you know where to get like the wire mesh? that goes behind the blinkers and can it go in the front too? thanks- my kit didnt come with it in the front, only small rear mesh pieces? and is it expensive? thanks mine only had mesh in the center section of the front bumper and the two small "vents" in the rear, not i went to home depot and bought mesy for the sides of the front but after i fitted the marker lights i noticed that that was really not needed as it reduces the size of the open vent, you can see it in the picture. mesh is pretty cheap it just depends how heavy (thick) you want it, i went with a light mesh so it was less noticable as it got painted and i didn't want it to notice.... -------------------- You're here for a good time, not a long time. - Colin McRae When in doubt... Flat out! - Colin McRae Understeer is when you hit the wall with the front of the car. Oversteer is when you hit the wall with the rear of the car. Horsepower is how fast you hit the wall. Torque is how far you take the wall with you.... |
| Lo-Fi Version | Time is now: August 23rd, 2026 - 1:29 AM |
