Feb 8, 2010 - 11:19 AM
Enthusiast ![]() ![]() ![]() Joined Feb 8, '10 From North Carolina Currently Offline Reputation: 0 (0%) |
I have a 94 celica st 5 speed. Ive recently been researching gt-4 swaps. Id like to do a full gt-4 swap on my car. I have the 7afe(1.8l) motor with the 5speed tranny in it. I need advice and help with my plans. Id like to put the 3sgte(2.2) turbo motor along with the 5speed awd tranny in my car. Id like to know helpful tips, tricks, and anything that might help me along with the swap. I know the the electrical part of the swap will be a complete nightmare but im willing to do it. Anyone with any knowledge on how i should go about do this please let me know.
Feb 8, 2010 - 11:27 AM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 5, '09 From Oakley, CA Currently Offline Reputation: 15 (100%) |
Please search. There's so many topics here that will help you its not even funny. Search for "3sgte swap"
-------------------- 1996 Toyota Celica GT (GT4 conversion) - SOLD :(
2002 Audi A4 1.8T Quattro - Daily Driver |
Feb 8, 2010 - 11:49 AM
Enthusiast ![]() ![]() Joined Feb 24, '09 From Scranton, PA Currently Offline Reputation: 13 (100%) |
i believe teh 3s enigne is a 2.0 and ur gonna have a little bit harder time becuase the enigne mounts r in different spots than a 5s or 3s but good luck and keep us updated!
Feb 8, 2010 - 12:20 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Aug 12, '07 From Lancaster, Pa Currently Offline Reputation: 35 (100%) |
ok well first off... like the other guys said do research... i'll be nice and start ya out though.
1. 3sgte is a 2.0 not a 2.2 2. there are different generation 3sgte engines. most us use the 2nd or 3rd. 3. go 3rd gen lol. i like the air to water and the ct20b is a nice feature. wiring is also easier because third gens were in 6gc. 2nd gens were in 5gc and mr2s. 4. you will need new engine mounts and trans. the "a" and "s" are not compatible. 5. have money in your pocket like any swap, or car project for that matter... talk is cheap. good luck. do your research and hope you get to swap. -------------------- |
Feb 8, 2010 - 12:51 PM
Enthusiast ![]() Joined Nov 27, '09 From New York USA Currently Offline Reputation: 5 (100%) |
You do have a lot of work ahead. And like garin said. You'll need money. I think specially for unexpected. since you will only find out how much it is until you are putting the car back together.
Besides this. Good luck |
Feb 8, 2010 - 2:57 PM
Are you talking just a 3SGTE swap? Or a Full AWD swap? Because there is quite a bit of fabrication required for the AWD swap. Mounts for the rear end, GT-four gas tank, cutting out the pan in the hatch, or going to a fuel cell.
The 3SGTE swap is WELL documented in the stickies at the top of the Forced Induction forum. Go look and read up. -------------------- 1991 MR2 - T-tops - Crimson Red - Gen3 3SGTE - Lots of money
Feb 8, 2010 - 3:55 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 15, '08 From Royal Oak, MI Currently Offline Reputation: 7 (100%) |
OP - got deep pockets?
-------------------- God made man....
Everything else... Made in China ![]() |
Feb 8, 2010 - 4:30 PM
![]() Enthusiast ![]() ![]() ![]() Joined Aug 25, '08 From England Currently Offline Reputation: 1 (100%) |
Looking at the parts catalogue The GT4 floorpan isnt that far different from the non GT4 floorpan (I once thought they were very different)...the bit where the spare wheel goes is different, you could cut that out along the existing spot welds and weld in a new one which would be a perfect fit....very little if any jigging required...other than that they are the same....its just that the GT4 (ST205) has extra bits welded to it to support the rear sub frame etc...all you need is the part numbers for the extra bits which should be obtainable from Toyota Dealers...welding those to the existing floor pan shouldnt be that difficult as they will be made to fit perfectly....once welded into position the rest would be fairly easy......expensive to get all the parts, but not beyond a competent welder and a deep pocket.
You`d have to double check the EPC just to make sure I havnt misread the part numbers and got it wrong...I`m thinking back to a couple of pictures that Garyst165 posted up a week or two ago from the EPC so it may be an error on my part, but worth checking up on....you might all be able to make your own GT4s easier than currently thought. This post has been edited by Nial: Feb 8, 2010 - 4:32 PM -------------------- |
Feb 8, 2010 - 8:52 PM
that you all for the support and hints. I have been researching this for a while and have finally got into a good financial state to start getting into it. Im pretty sure once i get the mounts and fuel tank and everything sorted out i should be fine. but does anyone know a good place to find parts?
Feb 8, 2010 - 8:59 PM
Enthusiast ![]() ![]() ![]() Joined Apr 23, '08 From boston MA Currently Offline Reputation: 5 (100%) |
it can be done
Feb 9, 2010 - 3:15 AM
but does anyone know a good place to find parts? The UK -------------------- |
Feb 9, 2010 - 9:31 AM
i was thinking about it last night, and i heard someone say that the 3sgte motor and the 5sfe were practically the same and the trannys would bolt up just find. i was thinking that since it would be alot less costly and alot easier to find parts that i could use the 5sfe motor, bolt on the 4wd tranny and turbo it myself later on. If anyone thinks theres any problems with it, please let me know
Feb 11, 2010 - 12:46 AM
Enthusiast ![]() ![]() ![]() Joined Nov 27, '09 From Canada Currently Offline Reputation: 4 (100%) |
they are NOT "practically the same". Only the motor mounts are.
Feb 12, 2010 - 12:07 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 28, '07 From Banland Currently Offline Reputation: 1 (100%) |
The 3sgte is turboed from the factory,meaning the engine came from the factory built to handle boost.The 5sfe was NEVER factory designed to hold boost,thus u have to upgrade a lot of parts to make it capable.For the the cost of getting a 5sfe and reliably turbocharging it you'd spend just as much to just initially buy a 3sgte.If u plan to do the awd swap(regardless of engine) u better to be ready to fork out 5k+ just for the reliable awd drive train.The 5sfe and 3sgte mount on the same places in the engine bay because they are both S series blocks,5Sfe,3Sgte,compared to 7Afe.The 5sfe stock transmission(s54) can be mated to a 3sgte,but wont hold over 300whp,and is of course FWD.For a 3sgte awd swap into a ST u better be ready to fork out around 10k...
If your serious about getting parts message member _Jim_(click me) and he can hook you up with most of the big parts This post has been edited by CelicaST_CALI: Feb 12, 2010 - 12:13 AM -------------------- BANNED. for life, you moron.
Feb 12, 2010 - 7:07 PM
I don't mean to be a Debbie Downer, but for the cost of the AWD conversion, you might as well import a real GT4. Don't get me wrong. I'd love to see this thread happen and I'd love to see another AWD conversion, but it's almost easier to just get the real thing.
Feb 12, 2010 - 7:20 PM
I don't mean to be a Debbie Downer, I resisted commenting when I first saw that in that other thread, but now I just HAVE to. An import isn't gonna happen, isn't the OP in USA? -------------------- ![]() |
Feb 23, 2010 - 12:21 PM
Enthusiast Joined Feb 21, '10 From St.Louis Currently Offline Reputation: 0 (0%) |
If you need a Celica ST205 engine harness for ur swap, ill let mine go for cheap.
Feb 23, 2010 - 12:35 PM
Enthusiast ![]() ![]() ![]() Joined Jun 10, '07 From Riverside, CA Currently Offline Reputation: 4 (100%) |
I don't mean to be a Debbie Downer, I resisted commenting when I first saw that in that other thread, but now I just HAVE to. An import isn't gonna happen, isn't the OP in USA? An import is possible if you use the imagination, or own a business And yeah, the OP is in NC -------------------- |
Mar 4, 2010 - 3:45 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Nov 10, '09 From Louisiana Currently Offline Reputation: 5 (100%) |
Have military friends over seas my buddy is in the marines and he has a list of cars he can import for free. You just have to get rid of parts to pass emissions. That's what he was telling me he said he can import 2 cars like every 1-3 years for free. He's shipping over a rx7 for himself ATM.
Mar 4, 2010 - 7:47 AM
Enthusiast ![]() ![]() ![]() Joined Sep 22, '08 From Bergenfield Currently Offline Reputation: 5 (78%) |
If your serious about getting parts message member _Jim_(click me) and he can hook you up with most of the big parts Yes, I have 3 complete AWD drivetrain components. Everything from trans to rear diff and cradle. PM if you are interested. --------------------
| Lo-Fi Version | Time is now: August 31st, 2026 - 11:47 PM |
