> I Need some help, I think i messed up
post Feb 21, 2010 - 6:21 PM
ravinaziankid
Joined Sep 11, '09
From NYC
Hey, so I was getting ready to show my car to a buyer and thought maybe I should test drive and all beforehand. After driving for a few mins, I pull out my SAFC2 and go through the categories. I go to car select and it asks the cylinder and its set at 4 and the Up arrow, but I accidentally changed it and it went to down and then the two stars, this is all while the car is at idle. When it changed to the down, the car started to bog down and the idle got rough, I immediately changed it back to Up and exit the screen back to the main menu.
I don't know if what happened after was the cause of my stupidity, but the car started to idle really rough and low to the point where it feels like its stalling, then the car stalled. When I restarted the car back up the idle was rough and low and felt like it was going to stall. I press on the gas and it would bog and then stall. I look at my boost gauge and there seems to be a vacuum leak or something because it's reading around 10, usually it's at 21. I look under the hood, and i smell fuel and see some fumes coming from around the IM area. I think its the fuel injector area and near the throttle body area as well. I am really not sure what the problem is. I now have a CEL and when i drive, i can hear a big vacuum leak, kinda sounds like im spooling and if i let go i hear either my wastegate or a psssh sound. Anyone have any idea what this can be? I am confused and really upset because I was just about to sell this and this happens.
Cliff: My car idles rough, low rpm idle, stalls at times when i press the gas, CEL is on, car sounds like a constant BOV or boost leak while driving. Couldn't find any vacuum leak anywhere.
post Feb 22, 2010 - 12:48 PM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
QUOTE (ravinaziankid @ Feb 21, 2010 - 6:21 PM) *
Cliff: My car idles rough, low rpm idle, stalls at times when i press the gas...
lol this makes person # 2 with the same problem as me(fate).. If you check my thread thats the problem im having with my car as well. I'm still researching the cause of the problem bro. Hopefully I will have the solution soon.
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
post Feb 22, 2010 - 10:43 PM
It would help to know what engine you have and what modifications are done to your car. Is this a 5sfTe setup or what?
Did you check the ECU to see what the CEL code is about?
This post has been edited by lagos: Feb 22, 2010 - 10:51 PM
post Feb 23, 2010 - 12:17 AM
ravinaziankid
Joined Sep 11, '09
From NYC
This is for a 5sfte, I haven't gotten a chance to get the code read. Autozone only had the obd2 scanner..i'm just hoping it's something easy like spark plugs since they were covered in carb the other day i checked them.
post Feb 23, 2010 - 12:22 AM
QUOTE (ravinaziankid @ Feb 23, 2010 - 12:17 AM) *
Who did the install?
Sounds like a problem with either the map sensor or the safc. Could be a wiring problem with the safc or maybe you cleared out your settings. Did you check the low/high throttle map to make sure there were negative corrections still there?
You don't need autozone to read the code of an obd1 car. You do it yourself with a paper clip in the diag box between te and e1, and then count the flashing cel light to read the code.
post Feb 23, 2010 - 12:27 AM
ravinaziankid
Joined Sep 11, '09
From NYC
The swap was done by the previous owner and some members of this site like presure and batman along with some others..
The car was running perfect a few minutes before and didn't have any signs of problems.
Oh this is my first time dealing with obd1 CELs..so i would just stick a paper clip in te and e1 and count the number of flashes the CEL has? That's pretty easy..is there a code list somewhere to tell what it is from the number of flashes?
post Feb 23, 2010 - 3:36 PM
bccentaur3
Joined Jan 29, '07
From Hoyt Lakes, MN
Count the flashes and get back to us. We'll let you know what it means. If you dont want to wait.
OBD1 Codes
1 Normal Condition.
2 Air Flow Meter signal.
3 Ignition signal.
4 Engine Coolant Temperature Sensor signal.
5 Oxygen Sensor.
6 RPM signal (Crank Angle Pulse).
7 Throttle Position Sensor signal.
8 Intake Air Temperature Sensor signal.
9 Vehicle Speed Sensor signal.
10 Starter signal.
11 Switch signal.
11 ECU/ECM.
12 Knock Control Sensor signal.
12 RPM signal.
13 Knock Control CPU (ECM).
13 RPM signal.
14 Turbocharger Pressure.
14 Ignition signal.
21 Oxygen Sensor.
22 Engine Coolant Temperature Sensor signal.
23 Intake Air Temperature Sensor signal.
24 Intake Air Temperature Sensor signal.
25 Air-Fuel Ratio Lean.
26 Air-Fuel Ratio Rich.
27 Sub Oxygen Sensor signal.
28 No. 2 Oxygen Sensor signal.
31 Air Flow Meter signal (Vacuum Sensor signal).
32 Air Flow Meter signal.
34 Turbocharger Pressure signal.
35 Turbocharger Pressure Sensor signal.
35 HAC Sensor signal.
41 Throttle Position Sensor signal.
42 Vehicle Speed Sensor signal.
43 Starter signal.
51 Switch signal.
52 Knock Sensor signal.
53 Knock Sensor signal.
54 Inter-cooler ECM signal.
71 EGR System.
72 Fuel Cut Solenoid signal.
78 Fuel Pump Control signal.
81 TCM Communication.
83 TCM Communication.
84 TCM Communication.
85 TCM Communication.
94 Celica gt white (sold)
post Feb 23, 2010 - 4:06 PM
Issue is mostly likely the SAFC
post Feb 23, 2010 - 4:20 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
It is very possible that you turned the corrections OFF. I did this once, basically the same way you did...just scrolling through the SAFC looking at the settings. I had very similar symtoms. Rough Idle, way rich, etc. I never stalled though, nor threw a code. Go to the corrections section and do as Art (Lagos) said....look for negative corrections.
Double check that for the "sensor" selection, the pressure is chosen. Anything else will not allow the car to run. You may have accidently switched settings.
330whp 309ft/lbs @ 21 PSI
post Feb 23, 2010 - 4:23 PM
ravinaziankid
Joined Sep 11, '09
From NYC
OK, I will give that a try..yeah it all happened after I was messing with the SAFC. I will update if that was the problem.
post Feb 23, 2010 - 4:44 PM
ravinaziankid
Joined Sep 11, '09
From NYC
I feel dumb now..it was on the wrong sensor setting, it was set on karman and not pressure..but at least now everything is fixed and running. Thanks a lot guys.
post Feb 23, 2010 - 5:03 PM
_Jim_
Joined Sep 22, '08
From Bergenfield
Its actually fairly easy when messing with the SAFC scrolling threw, looking at settings to switch to a different sensor setting without realizing. Glad it was a quick fix.
post Feb 23, 2010 - 5:13 PM
ravinaziankid
Joined Sep 11, '09
From NYC
Thanks again..this is one of the best forums for info and help
post Feb 23, 2010 - 10:22 PM
SlvrCelica09
Joined Jan 10, '09
post Feb 23, 2010 - 11:00 PM
QUOTE (SlvrCelica09 @ Feb 23, 2010 - 10:22 PM) *
Less posting and more time under the hood would help. There is only so much that people can recommend over the internet.
Lo-Fi Version Time is now: August 26th, 2026 - 4:53 AM
