> radio not working
post Feb 26, 2010 - 1:53 AM
kevinkoda
Joined Dec 2, '09
From Chino Hills, CA
so i installed an aftermarket headunit..a cheap kenwood just for my subs..and whenever i put on the radio...its all static and my antenna does not raise at all...any help? thanks
post Feb 26, 2010 - 2:29 AM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
make sure you connected your antenna to the back of the deck!
post Feb 26, 2010 - 3:07 AM
Prometheus
Joined Apr 5, '09
From B.C. Coquitlam
our radio antennas are powered so they wont extend unless they get power from your headunit, which could be why your getting bad reception?
post Feb 26, 2010 - 3:48 AM
SoDo
Joined Dec 16, '07
From Chicago, IL
connect the head units antenna wire to the cars auxiliary wire
This post has been edited by SoDo: Feb 26, 2010 - 3:50 AM
1999 Celica GT Hatchback
post Mar 1, 2010 - 9:59 PM
kevinkoda
Joined Dec 2, '09
thanks for the help guys..i think theres no input for the antenna wire to go to the back of the headunit. no worries..did my s2k antenna swap and radio works fine now smile.gif
post Mar 29, 2010 - 6:01 PM
conus00
Joined Jul 10, '08
From Tampa, FL
Sorry to hijack your thread but I have radio problem too and don't want to start a new thread:
Time to time my radio completely resets on the start of the car (i.e. loose all the settings, presets etc.) I have professionally soldered and insulated all the harness connection (no crimping) and double-checked everything. No loose ground. Anybody has experienced similar glitch?
'94 ST
post Mar 29, 2010 - 8:12 PM
Prometheus
Joined Apr 5, '09
From B.C. Coquitlam
QUOTE (conus00 @ Mar 29, 2010 - 4:01 PM) *
i also had this problem on one install. your 2 power wires 12v and ignition may be reversed.
you will lose all settings if the constant power supply is wired to ignition because uhh ignition isnt constant haha
post Mar 29, 2010 - 10:27 PM
conus00
Joined Jul 10, '08
From Tampa, FL
QUOTE (Prometheus @ Mar 29, 2010 - 9:12 PM) *
I will definitely check on that but I don't think so. That would cause the stereo to reset EVERY time but my problem is "hit and miss".
'94 ST
post Mar 29, 2010 - 10:32 PM
Wobbly connection at power source?
This post has been edited by SwissFerdi: Mar 29, 2010 - 10:32 PM
'90 MX-5 Mariner Blue
'15 Optima Grey
'04 206 GTi silve
post Mar 30, 2010 - 11:01 AM
SlvrCelica09
Joined Jan 10, '09
From Burtonsville, Maryland
QUOTE (Prometheus @ Mar 29, 2010 - 8:12 PM) *
this should be the reason. if you have a non name brand head unit these 2 wires are confused 100% of the time. GL
THIS IS WHERE WE HOLD THEM!
Still trying to find the cure for ST205 asthma..
6gc.net's outlaw vigilante because im a LEADER not a follower.
Lo-Fi Version Time is now: August 25th, 2026 - 2:48 AM
