Nov 10, 2003 - 8:11 PM
Enthusiast ![]() ![]() ![]() Joined Oct 27, '02 From Barbados Currently Offline Reputation: 0 (0%) |
VlaCelica Quote from http://www.6gc.net/forums/index.php?act=ST...=100#entry73624
"I got a question tough. I got a 3SGE engine that is about 175 hp stock (thats what is listed here in the netherlands, but i believe the engine should be 170 hp). What is the best (and cheapest) way to gain a bit more power without turbo charging it ? My goal is about 200 hp, and i want a faster 0-60 time. Stock its 8 seconds, and i want about 7 seconds. Got any tips on this one ? Also, if i would have alot of money, cant i just replace all the parts of my 3SGE engine with parts of the GT4 3SGTE (3rd gen) engine ?? Is this possible or do i need major adjustments to do this ?" I believe that every car should be fully tuned. Spark plugs, oil, filter change and so on. Please let me know how you normally drive. I use to drive flat out all the time. Now, I am trying to save gas. Sometimes, I have a little fun. But when I get serious, I crank the fuel up and lets have it. Look forward to your reply before I answer. This post has been edited by west_minist: Nov 10, 2003 - 8:20 PM -------------------- West_Minist
Hydra EMS Dealer & Tuner Subaru ECUFlash Tuner http://www.socob.bb http://xtremeracingtuning.com Viciously Tuned, Driven Hard ![]() |
Nov 10, 2003 - 8:28 PM
Enthusiast ![]() ![]() Joined Apr 28, '03 Currently Offline Reputation: 0 (0%) |
lol, few ways you could go. More aggressive cams will bring you up to where you want to be, but that level would cause rough idling and kill daily driving comfort. Could also go with a properly tuned EMS, but that's rather pricey. Then there's the SC kit by JapSpeed, but that's UBER pricey.
Edit: High Compression Pistons would also achieve some benefit. This post has been edited by Rivo: Nov 10, 2003 - 8:29 PM |
Nov 10, 2003 - 8:33 PM
the degree of cams would cause some problems. 264 would be good
A nice Autronics would do good. Have them there in netherlands. The have high compression pistons already. Advice a small turbo with max 6-8psi of boost. But stated above, I have to wait on what he will tell me. -------------------- West_Minist
Nov 11, 2003 - 2:43 AM
Enthusiast ![]() Joined Nov 10, '03 From Netherlands Currently Offline Reputation: 0 (0%) |
Well to answer ur question. I drive very relaxed... normally my rpm is between 3000 and 4000. This is cause i have to drive a lot every day to my work and back. There is no need for some extra power there. But, in the weekends i like to go all the way.
So it would be nice 2 have drivability comfort, but also some more power for the times i want to. Thats why my goal aint 250 or 300 hp like some others. I just want some more acceleration and power in the lower RPM's. I was thinking of getting HKS camshafts, camgears and valve springs. Together with a Jun flywheel, an apexi air intake and a HKS silent high power exhaust system. I think this will help me get some more power, just dont know it for sure. But those mods cost about the same as a Top Fuel turbo kit. But i wonder if the Top Fuel kit is enough to fit right. Cause it doesnt have an intercooler, and i think i would have to tune more stuff to make it work right. And that will cost me a lot more. Any advice is appreciated. PS, that small turbo sounds good, but are there any complete kits that i can buy that includes everything i need 2 make it work right without problems ? Got any websites where i might purchase such turbokit ? This post has been edited by VlaCelica: Nov 11, 2003 - 2:45 AM |
Nov 11, 2003 - 1:09 PM
My advice to you is to get an Autronics SM or SM2 ECU.
Why, you have them there and there are tuners there. I would also advice a Jun Flywheel, MSD Digital SCI Plus or a MSD Digital 7 Plus w/ HVC II coil. If you go with the Autronics, get the MSD DIS-4 Ignition controller which will allow a coil per cylinder. The Apexi filter and HSK Hi-Power also sounds good. Get some Hyperground Cables and some MSD ignition cables. Drop the car a bit with Tein or JIC or Cusco suspension. A bigger cam will require you to rev a little bit more to make power. Go with 264. It is very possible that you can go on the hks forum and ask for a turbo kit for the 3sge for 250 flywheel HP. There have all the parts that you can use., since majority fits the 3sgte. Spend some tine with blitz or hks. Even Jun can help you for what you need for your application. I will check my turbomagazine. There is a kit for the 3sge that was use on a lexus IS300 I think. But a lexus. The main problem with a turbo setup is the delivery of oil. -------------------- West_Minist
Nov 12, 2003 - 12:58 PM
Ok thanx for the info. very appreciated ! But what the hell is an autronics sm ecu ? never heard of it. We got plenty of tuners around here, but i havent seen any with experience on toyota's (its mostly honda, subaru, and that europian crap like VW, audi and BMW). I have done some research on parts from HKS, and they are really good, but most of them are created for the 3sgte, and not for the 3sge. Will this fit anyway ? Or do they have to make them custom if i want 2 ? Tnx again for the help. |
Nov 12, 2003 - 4:32 PM
It depends on what parts you are looking for.
My understanding that the cams will fit. The pistons and so on. Will you want to go to turbo charging at 5psi? -------------------- West_Minist
Nov 12, 2003 - 5:52 PM
Enthusiast ![]() ![]() ![]() Joined Sep 23, '02 From local petrol station!, UK Currently Offline Reputation: 0 (0%) |
i was going to ask the same question - guess you beat me to it!!
how much difference will a flywheel make?? (Is it worth getting new one, or lightening the existing one??) im still not sure about cams, i was told they can give up to 20 - 25 bhp extra (3sge) - but not sure what to get yet better spark plugs and leads - any noticible diference?? -------------------- 1996 UK white ST205
1998 UK silver ST202 ![]() Nothing is fool-proof to a sufficiently talented fool!!! |
Nov 12, 2003 - 6:26 PM
Any new cams with make you rev a little more to get power and it all depends on setup.
I would advice to buy a flywheel that to lightened it. The flywheel will make you accelerate faster, and make the engine responsive. The only problem that it is hard to keep the revs there once come on the clutch. -------------------- West_Minist
Nov 13, 2003 - 1:25 AM
ok i will mail hks, perhaps they will reply. Cause if i can use 3sgte parts, then im sure i can get that 200 hp in notime. Turbo charging at low psi is not a problem for me, as long as it gives me a nice boost. This post has been edited by VlaCelica: Nov 13, 2003 - 1:26 AM |
Nov 13, 2003 - 7:07 AM
how would you get past this problem?? -------------------- 1996 UK white ST205
Nov 13, 2003 - 7:58 AM
oh...and i forgot to ask, how much difference does an uprated fuel pump make?
basically, is it worth spending money on little things like better spark plugs and so on, or rather to save that money and spend it on other stuff. -------------------- 1996 UK white ST205
Nov 13, 2003 - 2:50 PM
![]() Enthusiast ![]() ![]() Joined Apr 8, '03 From NorCal Currently Offline Reputation: 0 (0%) |
IMO, it's not worth it. An upgraded fuel pump is not gonna add power. Basically, it can pump larger amounts of fuel. It's not necessary as a performance mod unless your engine is starving for fuel because of some form of forced induction. Upgraded spark plugs/wire and such also are not a performance modification, unless your car actually needs to have its plugs replaced, then you'll feel slightly better gains because your old plugs were not longer efficient. Also, if you have very heavy mods, then maybe an upgraded ignition system will nab you a few ponies here and there, but it's really not a "performance" mod. Save your money, do mods that count. |
Nov 13, 2003 - 5:46 PM
All true!
To keep the revs there, do not see why!!! use some 19" rims or even 20". It is better to start with basic mods and go from there. If you are turbocharging. It is slightly different. Injectors, boost control to my believe is the most important factors when relly thinking about turbo or over supercharging. -------------------- West_Minist
Nov 14, 2003 - 7:20 AM
i've got 18" rims, so that should be alright?? (And i don't want to turbo - not yet anyway) -------------------- 1996 UK white ST205
Nov 14, 2003 - 11:23 AM
Why do want to lightened the flywheel and still bothering about keep revs. In racing, there is no need for this.
Nov 16, 2003 - 4:01 PM
Enthusiast ![]() ![]() ![]() Joined May 1, '03 From Michigan Currently Offline Reputation: 0 (0%) |
You may want to contact Fensport or TDI in the UK. They have done a fair amount of work on the 3rd gen 3SGE's. Here is a link to TDI's site:
http://www.tdi-plc.com/toyota_celica.html#...95%20ON%20ST206 I have a 3rd gen 3SGE as well, imported from a 95' Curren. I also have a 3rd gen 3SGTE from a ST205. Asside from the high compression pistons, more aggressive cams, injectors and manifolds - they are the same engine. I was in the process of turbo-ing it before my job fell apart, now it's on hold. Here is the route I took: Swapped pistons with stock 3SGTE - needed fo running higher boost, you could probably get away with 5 - 7psi on the stock pistons. Replaced injectors with Denso Top feed 550's (the 3SGTE injectors are all side feed, the 550cc top feed injectors are usually found on upgraded Mitsubishi's). Very plentiful and cheap in the US. Replaced exhaust manifold with the stock ST205. You could also use the stock turbo and DP. Added a used Greddy FMIC ($400). Very easy to do with the side mount TB. Bought a used 3rd gen powered MR2 ECU and switched some wires around. If I didn't swap out the pistons, I would have just used the 3SGE computer. Replaced fuel pump with stock ST205 pump. Used the stock FPR from the 3SGE (same as the 3SGTE). And thats it! I've gone a bit further then this, but if your looking for budget performance this is all you really need. -------------------- Scott
West Michigan |
Nov 17, 2003 - 12:58 PM
Thanx for the info. I was thinking of replacing the engine parts with stock 3sgte parts. But on the other hand, that link u showed me of TDI looks good. So with all those mods i can get 29 hp more power right ? This is exactly what i need. I wonder what my 0-60 time will be then. Around 7 ??? |
Nov 18, 2003 - 12:14 AM
Possibly? Not exactly sure.
Do you have the trans with the LSD option? If not, you should look into it - grip is always a sure way to increase your 0-60 time. I know there are a few options for aftermarket LSD units. I remember how many times I've broken the tire's loose on my old 5SFE Celica GT - and that only had 135HP. I cant imagine holding 170HP to the ground. Do you often find yourself loosing traction on take-off? -------------------- Scott
West Michigan |
Nov 18, 2003 - 1:46 PM
I only have problems with grip when its wet. When the road is dry i dont have any problems with it at all. But when it raines i got a big problem lol. My car is going like all over the place, i dont have grip at all. 2 much wheelspin. |
| Lo-Fi Version | Time is now: May 24th, 2026 - 7:26 PM |
