Jan 15, 2003 - 11:34 PM
Enthusiast ![]() ![]() ![]() Joined Nov 12, '02 From Columbus, Ohio Currently Offline Reputation: 15 (100%) |
Who's knows how to paint a dash board? What kind of paint do you use? Do you clear it when you're done? What's the procedure?
Jan 17, 2003 - 11:31 AM
![]() Enthusiast ![]() ![]() ![]() Joined Dec 27, '02 From Sleep in Warren chill in clinton twp, works/school in detroit Currently Offline Reputation: 1 (100%) |
pry dash insert out
sand primer sand primer sand paint paint clear put back dash insert This post has been edited by rlan214: Jan 17, 2003 - 11:31 AM -------------------- |
Jan 17, 2003 - 11:33 AM
Jan 20, 2003 - 9:10 PM
I finally found some info on this. This best thing to use is a vinyl dye. Certain paint stores can actually fix the paint for you. Some can put it in a spray paint can for you. If not you'll have to use a spray gun. The vinyl dye permanently changes the color of the vinyl. They also make a spray paint for vinyl. When using this start out with 2 very light coats, so you can still see the original vinyl color, then apply a couple more coats a little heavier. Let dry. Finish up with 3 coats of clear coats. Let sit for at least 12 hours. Sand lightly with 500 grit sand paper if needed.
| Lo-Fi Version | Time is now: September 2nd, 2026 - 10:56 PM |
