> h1 hid on jdm projector problem
post Mar 29, 2010 - 10:56 PM
zd1818
Joined Oct 24, '09
From New Zealand
I tried different h1 hid kits. they can not be steady hold in the headlight, now im getting crazy,and im using glue...sounds stupid but its the only way Ican do,so the beam of light is actually not the on the right way.. see this picture http://i43.tinypic.com/2lu4dmw.jpg
im not in US could anyone please tell me if you did any modification on the light?the inside clip can not tightly hold the hid bulb... it must need something to match..
the actual looking of my JDM projector is http://i238.photobucket.com/albums/ff181/m...21/IMG_3067.jpg
is there any part missing?
This post has been edited by zd1818: Mar 29, 2010 - 11:09 PM
post Mar 30, 2010 - 1:33 PM
azian_advanced
Joined Apr 18, '05
From Calgary
My how to: install HID for JDM Projectors, my experience installing HID
post Mar 31, 2010 - 3:44 AM
zd1818
Joined Oct 24, '09
From New Zealand
thanks,got idea in mind. how can I know if the beam direction is correct?
post Mar 31, 2010 - 7:54 AM
azian_advanced
Joined Apr 18, '05
From Calgary
the beam is always going to be higher on the left like this: \____ \____ .. if that's what you're worried about..
post Apr 1, 2010 - 4:27 AM
zd1818
Joined Oct 24, '09
From New Zealand
thanks azian advanced, both left and right one look like \____ \____ when i park against my garage , I will upload more pictures later, thanks
post Apr 1, 2010 - 2:13 PM
Espo
Joined Aug 11, '09
From Buffalo, NY
There should be a plastic ring that came with the hid kit that you'll need to put over the bulb to hold it securely in place. You'll also have to cut a notch in the ring so it'll sit flush.
Lo-Fi Version Time is now: August 27th, 2026 - 11:30 PM
