> With or Without O2 Sensor?
post May 4, 2010 - 12:01 AM
fgvillegas
Joined Mar 22, '10
From Philippines
Hi,
Just recently, I learned the my O2 sensor is not functioning properly so I took out the connecting plug from the sensor to make the car run better than a damaged O2 sensor. From what I understand, with a disconnected plug from the O2 sensor, the ECU will use a default A/F ratio accross the entire RPM.
What if I maintained a disconnected O2 sensor and adjust the A/F ratio on a dyno, would this be better than reconnecting the plug with a brand new O2 sensor?
Thanks,
Lo-Fi Version Time is now: August 27th, 2026 - 1:21 AM
