> mr2 XTD clutch kit stage 3, would this go on a 5sfe celica?
post May 12, 2010 - 1:09 AM
sunwukongg
Joined Mar 10, '08
From Socal, OC
http://orangecounty.craigslist.org/pts/1702506369.html
would this go on a 5sfe celica? sorry if its a noob question
post May 12, 2010 - 5:39 AM
salman2510
Joined May 12, '10
From dhaka
It should fit, just make sure its of 225mm with 6 spuck and 20 teeth or spine. Think you will be fine
post May 12, 2010 - 1:01 PM
sunwukongg
Joined Mar 10, '08
From Socal, OC
QUOTE (salman2510 @ May 12, 2010 - 6:39 AM) *
thanks. and im aware my celica doesnt have the torque or power to benefit much from the stage 3 clutch. but im doing an auto to manual swap and im wondering if this is fine for my celica. only mods i have are short ram intake, headers, and custom 2.5 piping with a greddy evo 2 muffler
post May 12, 2010 - 3:08 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
i have a stage 1 street disc and it helps a bunch mostly when it warms up tongue.gif
but it will work as long as the motor in the mr2 was a 5sfe you would have too ask
"she can polish my strut bar anytime As long as her blow-off valve's in good order"
post May 12, 2010 - 5:48 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
you know that a stage 3 clutch is very very touchy right?
2001 Solar yellow Lexus IS300
post May 12, 2010 - 9:49 PM
sunwukongg
Joined Mar 10, '08
From Socal, OC
QUOTE (96stgreendemon @ May 12, 2010 - 6:48 PM) *
what do you mean by touchy? isnt it like super stiff?..haha sorry if its a noob question. i dont understand much about the Stage 1, stage 2, stage 3, and racing clutch thing. can someone tell me what the difference between those are?
post May 13, 2010 - 7:59 AM
96stgreendemon
Joined Oct 7, '09
by touchy i mean its stiff as **** and has almost no give at all to it, just stick with a oem clutch, or get a stage one, not that we even need it
post May 13, 2010 - 9:02 AM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
i can still get my stage 1 too slip if i completely mess up and its not stiff at all
id say go for it..
it wont be that bad and it will hold up a better to stress than a oem clutch/ IE.driving fast
post May 13, 2010 - 11:24 AM
richee3
Joined Jun 29, '08
From Denver
Kyle is right. You better start working out right now because your clutch pedal is going to be stiff. Yes, the clutch will help get a little more power to the wheels, but there will be a lot of clutch chatter. Takeoffs will not be nearly as smooth as an OEM clutch. Unless you plan on building a monster 5S-FTE, you're better off with a Stage 1 clutch. You sacrifice driveability with a stiffer clutch.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post May 13, 2010 - 3:54 PM
QUOTE (richee3 @ May 13, 2010 - 12:24 PM) *
clutches do NOT add power the upgraded materials and pressure plate allow it to hold more power without slippage.
a stage 3 clutch, on a near stock motor is 100% usless IMO.
pedal feel, clutch life, and driveablility all go down the higher stage of clutch you use.
post May 13, 2010 - 4:09 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
QUOTE (presure2 @ May 14, 2010 - 11:54 AM) *
but if you drive it hard isn't it better to have a higher stage clutch than oem?? Evan if stock?
post May 13, 2010 - 4:25 PM
richee3
Joined Jun 29, '08
From Denver
Good call, Manny. I forgot to elaborate. I said it helps get more power to the wheels, but not that it creates more power. It just loses less power. Agreed 100% though, anything over a Stage 1 clutch on a basically stock engine is overkill.
1998 Celica GT-
BEAMS Swapped.
post May 13, 2010 - 4:39 PM
QUOTE (terbear4god4life @ May 13, 2010 - 5:09 PM) *
not on a stockish car.
the stock clutch will give you the best feel, and longest life.
unless your turbo'd, anything more than a stage one is totally pointless IMO.
if your not planning on turboing, paying more for an aftermarket clutch is all about being able to say "i have a stage whatever brand clutch in my car". not more performance.
post May 13, 2010 - 5:49 PM
terbear4god4life
Joined Oct 10, '08
From sweet home, OR
idk its only 60 bucks id take it either way thats a hella nice deal.
Lo-Fi Version Time is now: August 25th, 2026 - 12:08 AM
