> need some help, about the clutch
post May 19, 2010 - 1:57 PM
Shigexile
Joined Oct 30, '03
From IL
i was driving and i noticed that my clutch won't come back up to the top. It seems like there is no pressure to push the pedal back up. So i'm thinking its the clutch fluid? If so, i don't know where the clutch fluid is or goes. Can someone help me out with this problem please?
post May 19, 2010 - 2:02 PM
GriffGirl
Joined Feb 7, '07
From Portland, Oregon
If there's no pressure pushing your clutch back up, either your clutch slave cylinder or clutch master cylinder has gone out. There's no actual "clutch fluid", as hydraulic clutches use the brake fluid. You'll need to replace one or both of the cylinders.
post May 19, 2010 - 2:18 PM
Shigexile
Joined Oct 30, '03
From IL
edit: deleted
This post has been edited by Shigexile: Jun 8, 2010 - 11:46 PM
post Jun 8, 2010 - 11:57 PM
Shigexile
Joined Oct 30, '03
From IL
so i ended flushing all the fluid out of the system and i believe all the air is out as well. The liquid was way too dirty so i thought that was the main reason why the clutch got stuck.
drove around and i will occasionally find the clutch creeping to the floor. This is exactly how it happens: i push the clutch through the free play it has gently and slowly. once i feel pressure i let go of the pedal but the pedals sinks to the bottom. If i push the clutch in quickly to the bottom i have no problem.
slave is not leaking, master shows max fluid level, and it only happens if i push the pedals slowly through the free play and let go.
So im kinda stumped to what to do next. Could it possibly still be a faulty slave/master?
thanks to griffgirl for helping me the first time around
post Jun 9, 2010 - 1:25 AM
Jamchell
Joined Aug 24, '09
From San Diego, Ca
There is a very good chance that the master cylinder is worn and letting fluid bypass the seals when you depress the pedal slowly, my 99 ranger had that problem(stupid plastic master cylinder). If you got all the air out, then it's even more likely. Sometimes clutch systems are a bear to bleed properly and you have to actually pressurize the system at the master cylinder to force all the air out.
post Jun 9, 2010 - 8:10 PM
replace the slave and master, rebleed, see how it does.
post Jun 10, 2010 - 12:52 PM
dabazied
Joined Jun 10, '07
From Riverside, CA
QUOTE (Bitter @ Jun 9, 2010 - 5:10 PM) *
^^^^ What he said, start with the master though. Might cure your problems there, if not then chip in the extra cash and replace the slave too. Both are easy to do.
She's Alive...... Again!!!
Sweet Jesus.
You rang?
Sorry, wrong number. :laugh:
Lo-Fi Version Time is now: September 12th, 2026 - 3:07 AM
