> amp installation
post Nov 17, 2003 - 9:35 AM
stormtrupr
Joined Nov 6, '03
From OH
i am installing an old amp to the stock system.
i have a built in amp and not the separate one.
i am tying into my rear speakers with a line converter to run to my amp and i am not sure if i have a remote power lead on the stock deck or not. what to connect it to??? i know that on another post in hear...they said the power lead which is usually red...but my rear speaker uses the red. any info on what color wires mean what...would help tremendously. i have a 96 st if that helps anyone.
thx again
storm
post Nov 18, 2003 - 12:56 PM
so your connecting an amp to a stock system...and ONLY the back speakers...?
You can always connect it to you KEY_ON wire...which will turn it on when ur turn ur car on...dunno which wire it is tho.
You can also run your own switch...where u run a wire from the BATT to the switch, and then from the switch to the amp. That way you can switch ur amp on and off whenever u'd feel like.
post Nov 18, 2003 - 9:38 PM
Cormudgen
Joined Jul 31, '03
From GA
i have mine running into the "IGN" fuse in the drivers kick panel.
cormudgen
post Nov 19, 2003 - 12:43 AM
UniStorm
Joined Oct 17, '03
From Huntsville, AL USA (Born and Raised in NY)
I believe the lead for the remote switch is orange and black. it be easier to wir to key_on though
Lo-Fi Version Time is now: September 4th, 2026 - 5:57 PM
