Jun 30, 2010 - 12:30 AM
Enthusiast ![]() ![]() ![]() Joined Oct 7, '09 Currently Offline Reputation: 8 (65%) |
how much differently does a stage two clutch feel rather than a stage one?
and is there any difference from an oem clutch and a stage one clutch? thanks for the help... also is there any difference in performance between them? thanks guys, i love knowing you smart ones.. haha -------------------- NOVAKx17
2000 Eclipse GT- DD=== oil pump went blown up and sold 1997 Celica ST- swapped and sold 2004 Ford explorer xlt 4x4- totaled 1997 Celica Convertible GT- Going Topless (; (18:32:21) yarik83: axel has a sensitive wife. i hear she used to be a lesbian and then became ferdi ( PARTING OUT A GT COUPE http://www.6gc.net/forums/index.php?showtopic=88592 ) |
Jun 30, 2010 - 1:12 AM
Each stage loses a little bit of comfort. Each stage grabs harder than the last, so it's less comfortable to drive on a daily basis. OEM clutches are the softest and easiest/most comfortable to drive. Perfect for a stock/basically stock engine. Stage 1 clutches are for the engines with a little bit more power. It will give a stiffer pedal feel. And it's really pretty pointless unless you're putting out quite a few more HP than a stock engine. Stage 2/3 clutches.. Yeah, just don't worry about those. You won't need them unless you start producing some big HP numbers. They won't help you out at all. Actually, they'll be a nuisance. A Stage 3 clutch, you can't just comfortably take off from a stop light with it. You pretty much just give it gas and dump the clutch. Each start will be rough. OEM clutches let you take off smoothly and comfortably. So really, depending on your power goals and mods, just stick with an OEM or stage 1 clutch.
Jun 30, 2010 - 4:15 AM
dont forget a higher stage clutch will also wear out your motor mounts faster then OEM clutches.
| Lo-Fi Version | Time is now: August 26th, 2026 - 8:46 AM |
