> New or rebuilt??, Driver side caliper
post Jul 30, 2010 - 3:11 PM
Bigblock
Joined Feb 14, '09
From Mid West
Driver side grinds and makes me whince!!
Next Thursday it's going in for brake work.
So if the caliper needs replaced,
New or Used??
I replaced the pads & rotors about a yaer ago, and started making noise 2 weeks ago.
Thanks for any input!!
No, I don't have what it takes to rebuild it myself.
I am driving the " other " car til she's fixed.
post Jul 30, 2010 - 3:58 PM
Spider77
Joined Jan 17, '08
From JB MDL, NJ
Rebuilt can be alot cheaper, so if its done right it'll be as good as buying a new one. Although just cause you get a new one. its not 100% that it is good either (real slim chance that its bad, but it does happen). Rebuilding a caliper is easier than you think though.
post Jul 30, 2010 - 5:01 PM
zfjohnson07
Joined Apr 11, '09
mine use to grind, bad wheel hub, and its griding again when i turn left, bad wheel hub again
post Jul 30, 2010 - 5:56 PM
Bigblock
Joined Feb 14, '09
From Mid West
AAAGGGHHH the grinding is nervewrecking!!
The rotor is worn out, so I'm hoping to just end up
replacing it & the pads!!
post Jul 31, 2010 - 12:36 AM
richee3
Joined Jun 29, '08
From Denver
The rebuild really isn't that hard, and it can be done for cheap. But I say if you buy it from a reputable place, a rebuilt caliper wouldn't be bad at all. Just buy from somewhere with a warranty.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Jul 31, 2010 - 1:06 AM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
new from toyota 200+
autozone/pepboys/advancedauto - 75
id recommend the rebuilt ones that pepboys and the others are selling.
that or a junkyard and grab one for $15
This post has been edited by Tigawoods: Jul 31, 2010 - 1:06 AM
エキサイティングカーレーシングチーム!
post Aug 2, 2010 - 3:44 AM
Raves44
Joined Mar 26, '09
From Colorado Springs
I have a set of rotors from my car cuz i put some dimpled and slotted ones on there. You can have them cheap they are in good shape and might save you some $ in the long run
post Aug 7, 2010 - 9:22 PM
AKPMD
Joined Feb 21, '10
From Toronto
Careful,
Based on my experience, taht grind can be due to a broken axel shaft, or due to bad wheel bearing.
Lo-Fi Version Time is now: June 24th, 2026 - 12:03 AM
