> Rear Speaker Installation, 6.5 inch easy?
post Nov 20, 2003 - 2:17 PM
celicagt94
Joined Feb 3, '03
From Maryland
How easy is it to install components in our rear speakers? Just a matter of taking vent off and unscrewing speaker or is it like the front and has a metal peice that goes around it?
thx
post Nov 20, 2003 - 5:04 PM
BenMMellor
Joined Dec 24, '02
From Wirral, UK
have a look on www.celica-club.co.uk .. one of our members did a how-to in a post..
post Nov 20, 2003 - 6:03 PM
I can't remember if I had to remove my backseat to remove my rear speakers, but I know I had to take off the entire side panel to access that area.
post Nov 20, 2003 - 8:55 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
you have to remove the rear seats by the bolts in the back of the seats, there are 2 on each seat. then just pull up on the bottom of the seats in the front and the surround will slide over the back mount. then just remove all the screws. its in a plastic mount but is removed pretty easy once you get the hang of it.
post Nov 21, 2003 - 12:39 AM
UniStorm
Joined Oct 17, '03
From Huntsville, AL USA (Born and Raised in NY)
QUOTE (PhillyGuy086 @ Nov 20, 2003 - 7:55 PM)
Huh? You just have to remove the side panels and voila!
post Nov 25, 2003 - 8:08 AM
van95st
Joined Sep 6, '03
From Fairbanks AK
if you don't mind a little advice i'd stick with components up front and then put some drivers in the rear. 1 set of tweeters is enough for the size of the cabin. The drivers will also give you more mid bass to compliment your system. And they are generally cheaper too. I used to have components both front and rear and then i switched and it sounds much better.
post Nov 25, 2003 - 7:29 PM
Makaveddie
Joined Dec 5, '02
From Sacramento, CA
I disagree. The rear fill is necessary for the full sound quality stage. I had just the components runnin in front, and it sounded horrible. Get some mids for the back. As for getting them installed, ya you gotta take out the back seats. The bolts are behind the seats on each bottom corner of the seat. Do the work, or get some one to do it for you. I did the work. smile.gif Ed.
post Nov 28, 2003 - 1:28 PM
PhillyGuy086
Joined Sep 18, '03
From Dirty Jersey
well do you have a hatchback or coupe? With the hatch you have to remove the rear seats to get the panels out. I dont know about the coupe though.
Lo-Fi Version Time is now: September 4th, 2026 - 11:21 AM
