Aug 12, 2010 - 11:56 AM
![]() Enthusiast ![]() ![]() Joined Feb 26, '05 From Sweden Currently Offline Reputation: 0 (0%) |
I've had my car for over five years now and the A/C has never been working. Today i decided it was time to have a look at it, and so it begins..
When I press the A/C button it lights up but the compressor doesn't kick in, it does however when I override the clutch with a separate wire directly to the battery. No problems so far, there are however two more wires coming from the compressor, what are these for? I read somewhere else that the compressor might not kick in if there aren't any refrigerant in the system.. is this correct? If so, how can i tell if there is any refrigerant in the system? I've tried to peek through the lens but I can't see anything.. I tried to override this by disconnecting a sensor on the lines (dunno if it was the right one though Anyway, I then decided to have a look at the relays. I thought that the A/C button simply controlled the A/C relay which in turn controlled the clutch magnet. This is where I completely lost my patience.. there are five relays, two of which belong to the ABS-system, two to the fans and one to the compressor. I thought it'd be a simple matter of bypassing the AC one to see if it kicked in or not, but when I did so the friggin fans went on instead?! I concluded that the AC relay simply wasnt where the lid said but despite this I haven't made much progress.. if anyone has any ideas or possibly a wiring diagram it'd be really helpful -------------------- ![]() |
Aug 12, 2010 - 11:16 PM
go get a can at wlamart and for 22 bucks you get a reader dial and if its low, refill it, and if its low the next day then you have a leak.
Aug 13, 2010 - 4:38 AM
![]() Enthusiast ![]() ![]() ![]() ![]() Joined Apr 28, '09 From York pa Currently Offline Reputation: 3 (100%) |
Aug 13, 2010 - 5:16 AM
I'm afraid we don't
It's nearly impossible to get a hold of R134a in Sweden without the right certifications, I suppose I have to get it filled at a shop which is ridiculously expensive does anyone know where the pressure switch is located, it'd be nice to know if the refrigerant actually is the problem before I throw away 700$ on filling it -------------------- ![]() |
Aug 13, 2010 - 8:05 PM
wow, sorry, did not realize. 700$ no way. ridiculous.
good luck -------------------- Learned a lot in 10 years... I hardly log in anymore, last login Today Sept 6 2019, and I was forced just to clarify a post. LOL
Aug 14, 2010 - 4:46 AM
ty, but yeah, it's apparently illegal to fill without first testing for leaks so I guess it adds on
awww, I just had to press the link in your sig didn't I.. *uyuyuyuyuyuy, nannanaaa NANANA* -------------------- ![]() |
| Lo-Fi Version | Time is now: August 11th, 2026 - 2:07 PM |
