> Difference in piston size?
post Aug 20, 2010 - 6:49 PM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
I was looking into some weisco pistons and I was wondering whats the difference between 79.5mm 82mm and 82.5 mm. Would there need to be any boreing out of the engine to make the bigger pistons fit? and are there really big power gains because of increasing the piston size. Any help in understanding this is much appreciated.
post Aug 22, 2010 - 12:31 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
other than the size, theres no difference. and es you will need to get the block bored for the exact size pistons you put in.. otherwise they wont fit(pistons bigger than hole)...or they wont seal and the motor wont run(hole bigger than piston)
very small HP gains from bigger pistons
post Aug 23, 2010 - 12:37 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
so whats the reason behind making bigger pistons for the same engine? im guessing maybe when you rebuild the engine they bore it out a little and you need bigger pistons or am i wrong?
post Aug 23, 2010 - 9:38 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
if the cyl walls get too scratched/damaged they need to bore it out untill its a smooth finish
post Aug 24, 2010 - 7:49 PM
you will get a slight gain with the higher displacement, but the big gains are when you boost it.
post Aug 25, 2010 - 10:37 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
I see alright thanks guys
Lo-Fi Version Time is now: August 28th, 2026 - 6:31 AM
