> Bass rattle help?
post Sep 14, 2010 - 5:53 PM
nwizzle
Joined Sep 12, '10
From Scottsboro, AL
So I have 2 12's in my trunk (hatchback) and it seems to rattle... just everything... The obvious thing was the hatchlid so i put washers under the bumpers to tighten it when it closes. I thought that would be it but I found out it rattled the panel on the inside of the lid, so I put a couple t-shirts between it and the door... Next I found that there was a space between the license plate light and the panel that was buzzing so i fixed that... now it seems that I can tell the whole thing the license plate sit inside of (above bumper between quarterpanel, you prolly know what I mean) is shaking only when hatch is closed, but when I close it and press down pretty hard that takes care of almost all the noise. I'm pretty sure that's the only thing I got left. Can anyone help me out? I can not figure out what to do about that other than glue weights to it and I feel that that might be a bad idea kindasad.gif I don't know much about systems in general other than what's good and how to install so there may be a simple product that can fix that, but for the car... That's a weird piece around the license plate, seems like I could do something about just that. Any advice will be appreciated. Thanka [=
This post has been edited by nwizzle: Sep 14, 2010 - 7:28 PM
post Sep 15, 2010 - 2:21 AM
freddy121389
Joined May 29, '09
From Lake Ariel, PA
dynamat sir google it smile.gif they also make a dynamat license plate stick on, I used to have on on my car but downgraded subs so the bass wouldn't shake my trunk anymore.
post Sep 15, 2010 - 9:09 AM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
there is a cheaper way to do it, air duct insulation from home depot
2001 Solar yellow Lexus IS300
post Sep 21, 2010 - 6:19 PM
SoDo
Joined Dec 16, '07
From Chicago, IL
Use roof and gutter repair tape. Dynamat is a rip off.
1999 Celica GT Hatchback
post Sep 21, 2010 - 6:28 PM
mkernz22
Joined May 10, '10
From MA
it's actually the housing that the license plate sits in, no the plate itself. I have the same problem as you. When I press down on the plastic part, no vibration. I have to figure out a way to make it stronger
post Sep 21, 2010 - 9:39 PM
nwizzle
Joined Sep 12, '10
From Scottsboro, AL
QUOTE (mkernz22 @ Sep 21, 2010 - 7:28 PM) *
Exactly...i cant afford dynamat but i got some insulation and put behind the panels, around the spair tire and I turned the subs around. it helped the general noise but not really the vibrating housing. I was actually thinking id get under the car and use some insulating foam from the backside... cant take the molded bumper off... any thoughts on that anyone? I could always just pay someone to sit behind my car and press down at stoplights and when im skating and stuff... 45 cents an hour lol
post Sep 23, 2010 - 3:23 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
buy a can or 2 of rubberized undercar coating. spray behind your rear plate bezel
Lo-Fi Version Time is now: August 9th, 2026 - 2:21 PM
