Sep 18, 2010 - 7:53 AM
Enthusiast ![]() ![]() Joined Mar 28, '10 From Columbia, South Carolina Currently Offline Reputation: 1 (100%) |
has anyone done this? What are the gains I should expect? I tried searching for this, but the one problem with this website's search is that it splits the words. Thanks in advance though!
-------------------- ![]() 1994 Celica GT, coupe, 5 speed. Front strut brace, cherrybomb glasspack, intake. |
Sep 18, 2010 - 8:18 AM
dont expect any gains. it wont add HP.
i removed mine just to make more room in the engine bay when i had the 5sfte. the evap canisters job is basicly to remove built up vapors in the fuel tank,IIRC, so what i did was remove the canister, and capped the line that goes from the canister to the line on the firewall, and i cut a little slit into the cap i used so that exess pressure in the tank can vent. i've read on mr2oc about guys doing the same, just drilling a hole in the gas cap instead to vent the pressure. -------------------- Former Team 5SFTE pro member ;)
Sep 18, 2010 - 8:26 AM
you can also simply relocate the canister to under the car nearer the fuel tank. removing it does nothing except vent unburned fuel into the air. evaporated fuel is a HUGE pollutant, worse than when its burned.
Sep 18, 2010 - 3:42 PM
What about the EGR and emissions delete?
| Lo-Fi Version | Time is now: August 31st, 2026 - 11:59 PM |
