> Can I use 9006/100W in low beams?, (instead of 9006/65W)
post Sep 25, 2010 - 6:47 AM
conus00
Joined Jul 10, '08
From Tampa, FL
One of my light bulbs bit dust and I need to replace it.
Further down the road I intend to replace both of them with Sylvania Silverstar Ultra 9006 SU/2 bulbs but right now I'm broke.
I know that stock replacement for low beams is 9006/65W but can I use 9006/100W instead without risking blowing fuses or melting harness?
'94 ST
post Sep 25, 2010 - 12:33 PM
richee3
Joined Jun 29, '08
From Denver
Currently Online
I've been running 9005 65w bulbs in my 9006 55w low beams for quite some time without issue, but I've never seen the 100w bulbs.
2006 Aston Martin V8 Vantage.
1998 Celica GT-
BEAMS Swapped.
2021 GMC Sierra AT4.
post Sep 25, 2010 - 12:36 PM
whatthe
Joined Aug 13, '08
From Australia
I rekon you will be riskying melting the harness, and ive never seen 100w bulbs. At least in australia, have you even thought about hids?
post Sep 25, 2010 - 8:43 PM
conus00
Joined Jul 10, '08
From Tampa, FL
Here is what I'm considering. I've been running similar (but 65W) for over a year now.
http://cgi.ebay.com/ebaymotors/ws/eBayISAP...e=STRK:MEWAX:IT
How serious is the threat of actually melting the harness?
'94 ST
post Sep 26, 2010 - 10:33 AM
conus00
Joined Jul 10, '08
From Tampa, FL
Nobody knows?
'94 ST
post Sep 26, 2010 - 4:47 PM
mkernz22
Joined May 10, '10
From MA
Straight from it's ad on ebay:
This Item is 100W Bulbs, Buyer Need To Check Wiring Or Fuse Before Installing
Just get an HID Kit for you car, don't risk messing something up with these poser HID bulbs.
post Sep 27, 2010 - 5:26 PM
conus00
Joined Jul 10, '08
From Tampa, FL
Can't afford HID conversion kit, right now...
Can't afford ticket for non-moving violation (i.e. busted headlamp) either. frown.gif
'94 ST
post Sep 27, 2010 - 5:47 PM
mkernz22
Joined May 10, '10
From MA
you got a ticket for having a broken headlight?...
post Sep 28, 2010 - 1:19 PM
conus00
Joined Jul 10, '08
From Tampa, FL
QUOTE (mkernz22 @ Sep 27, 2010 - 5:47 PM) *
Not now for this one, but I got one couple years ago... They call it "fix-it-ticket", as soon as you can prove it that it's fixed then you get the ticket wiped out clean, but you have to go to court and loose a day at work. Either way it's too much hassle. Trying to avoid it.
'94 ST
Lo-Fi Version Time is now: May 29th, 2026 - 10:37 PM
