Oct 24, 2010 - 12:34 PM
Enthusiast Joined Oct 17, '10 From uk Currently Offline Reputation: 0 (0%) |
Hi all,
Please can someone save me from a life of despair and depression. 1996 1.8 ST UK Model Long story short, bought my G6 a year ago (August 2009), two previous owners, FSH (including every receipt etc). After two weeks started to smoke badly. Went travelling came back Jan2010. Wanted to fix car. Decided to buy another engine and pop it in, only thing is I got ripped by some guy on ebay, sold me a 7AFE for an Avensis not Celica. So then decided to do a full rebuild on the original engine. When I took out the original and striped turned out the oil rings where sticking hence smoke. Due to hectic life, only just finished the rebuild. I have rebuilt the head, valves ground (hours of rubbing my hands together, I have the blisters to prove it!), new oil seals etc. Also replaced pistons, piston rings, all engine bearings, oil pump, timing belt, replaced all engine gaskets etc etc etc. I was pretty pleased when I had finished and had the engine back into the car. As there were no other problems prior to it smoking I was expecting her to fire up, she didnt. Not even close really, the engine just turns. Without being rude, I have checked all the obvious. Made sure the loom has been intalled correctly. There is petrol making it into the cylinders, a spark making it to the plugs(had the cap off to make sure signal is going to the correct plug), the timing is all ok as I have triple check it . I don't know why she wont start, after putting alot of cash into the car to give her a brand new lease of life I feel like hitting my head against the wall. I can not think of what it is that is not allowing the car to start ( I have turned off immobilizer before you ask) Please can someone help, very frustrated that all the hard stuff is done and probably something very simple stopping her from starting. Any advice is greatly appreciated. Kind Regards Devan This post has been edited by CA18DET: Oct 24, 2010 - 12:35 PM |
Oct 24, 2010 - 1:21 PM
Enthusiast Joined Oct 21, '10 From Sydney, Australia Currently Offline Reputation: 0 (0%) |
Did you also change the battery? Leaving it for so long you would have to get a new one now.
Oct 25, 2010 - 7:16 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
spin the timing 180 degrees (swap wires 1&4 with eachother, and swap 2&3 with each other)
or alternatively, pull the dizzy off, spin the key that mates with the cam half a turn and reinstall. achieves the same shizt. i had to do that on one of my motor builds -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Oct 25, 2010 - 7:37 PM
Did you also change the battery? Leaving it for so long you would have to get a new one now. Thanks, Battery fully charged and also using a battery from 5 series BMW with jump leads. @stephen_lee - Thank you. I have already tried that. It didnt make a difference. |
Oct 25, 2010 - 11:15 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
im sure you have already tried this but i will say it anyways.. did you turn the key to the on position a few times to prime the fuel pump and the system?
-------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Oct 26, 2010 - 5:12 PM
Hi all,
Thanks for your suggestions. I have located my error. Turns out the inlet cam was deceiving me. although the timing marks on the front were timed correctly, as I did not removed the inlet cam by placing a service bolt in it prior to removal. The cog jumped out of place, so the timing marks were correct but the cam itself was out. Inlet cam in vice, twisted, service bolt inserted correctly so installation mark on front and back lined up (previously these were two or three teeth out) and hey presto she started. Now there is a weird rattling noise I will investigate tomorrow ( its late now 11pm), however at least she starts and that is the main thing. Again, thanks. |
Nov 2, 2010 - 12:15 AM
Enthusiast Joined Nov 2, '10 Currently Offline Reputation: 0 (0%) |
spin the timing 180 degrees (swap wires 1&4 with eachother, and swap 2&3 with each other) or alternatively, pull the dizzy off, spin the key that mates with the cam half a turn and reinstall. achieves the same shizt. i had to do that on one of my motor builds -------------------- |
Nov 2, 2010 - 10:45 AM
yes?
| Lo-Fi Version | Time is now: August 29th, 2026 - 2:18 AM |
