> Scraping type noise when turning
post Oct 31, 2010 - 5:26 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Hey guys,
Not sure if this is the correct place to post, but it shall do for now.
For a while now i have been hearing a Scraping type sound from where i believe, in the Front Passenger side wheel... Only when i'm turning Left.
Any type of turns as well, little vears to the left, to hard turns, so its not the Power Steering either.
Its making a "shhhch shhhch" type sound if you can try understand that haha.
Through maintenance and servicing, i've had the wheel bearing tightened, both cv boots changed, and the brake pads aren't even at half way yet.
I've taken the wheels off and thoroughly cleaned and looked for anything caught, or scraping.
The sound was there before i installed my coilovers, and before my new rims i believe.
So it's got me quite stumped.
It SOUNDS as if its coming from the front when i stick my head out, but it could be transfering from the back of the car.
So if anyone has ANY help at all, it would be great. Its not a big concerning problem, but it's bugging the hell out of me.
post Oct 31, 2010 - 4:33 PM
BonzaiCelica
Joined Apr 24, '08
From Orange County, CA
well from my past experience when my friend and I changed my clutch. We disconnected the left side of the control arm to the bottom half of the strut in order to take out the axle and slide the transmission out and under of the car on the left hand side. There was a loud occurring noise when we would take right (being that the gravity would being pulling towards the left side of the car) turns and it would occasionally come up again when driving in a straight line. We were so confused as to what it was that it ended up being the brake dust cover. We had bent it. You know that cover that goes behind the brake rotor and has slits in it so I guess cool air can get to it. If you don't understand what part I'm talking about I'll try and get a diagram up.
post Oct 31, 2010 - 5:58 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
I also thought it was that. I got an air blower and blew all behind there in case anything was caught and pushed the cover back a bit incase it was rubbing. But there were no signs it was, so still stumped. I may check them out again, but they looked fine to me frown.gif
post Oct 31, 2010 - 7:16 PM
BonzaiCelica
Joined Apr 24, '08
hmm ya It would probably be best if you could get a sound clip of it or a video. Don't know what else to tell ya best of luck
post Oct 31, 2010 - 7:20 PM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
post Nov 2, 2010 - 12:08 AM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (Timmyface @ Oct 31, 2010 - 5:26 AM) *
How did you have the wheel bearings tightened? Sealed bearings can't be tightened or adjusted (unlike tapered assemblies on RWD cars and trucks that can be re-packed with grease and adjusted), if they have play or anything like that then they are bad and just need replaced. I'm betting that's what the problem is. If someone "tightened" it by putting more torque on the axle nut or something then all they did was cause it to wear out faster by putting more tension on it.
If a shop did it I'd be giving them an angry phone call for ripping you off on a service that's not used on these cars.
1999 Celica GT
post Nov 2, 2010 - 12:11 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Well yeah thats what the Mechanic told me. He checked it over to try find out what it was but only came up with that. He charged me for "Tightened LHS Wheel Bearing"
Theres not much play in it though.. Roughly the same amount as the Right hand side, so shouldn't the sound be coming from there as well?
post Nov 2, 2010 - 12:27 AM
blu94gt
Joined Mar 23, '05
From Kansas City
Well there shouldn't be any play at all. Sounds like your passenger's side is going out though if you have noise from the front right side when you turn left, since when you turn left all the weight is put on the right side.
If your front left has play in it though then it needs replaced too, even if it isn't making noise yet. I've seen them where they are loose but not making noise, and also seen ones that made all kinds of screeching and grumbling noise but didn't have any play at all. Wheels shouldn't have any play in them. Typically: up-and-down play is bad bearing or ball joint, side-to-side play is bad tie-rod.
Hopefully you get it figured out! Front bearings are pretty common repairs on these cars it seems.
Mods, I don't know if there is one yet but could we make a thread in the stickies about diagnosing wheel bearings and tie-rods? Seems like we've had a TON of wheel bearing threads lately and I think a thread with some good info would be very helpful.
1999 Celica GT
post Nov 2, 2010 - 12:29 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Cheers for that info. I might go out now and pull my wheels off again and check whats going on in there, and possibly make a phone call >.< haha
post Nov 2, 2010 - 12:35 AM
blu94gt
Joined Mar 23, '05
From Kansas City
Don't pull them off, just jack them up and try to wiggle the whole wheel.
Here's a good video of basically what to look for in case you aren't quite sure. (can we embed videos here?)
http://www.youtube.com/watch?v=JSsC-lWB1lg...feature=related
1999 Celica GT
post Nov 2, 2010 - 12:39 AM
Timmyface
Joined Apr 17, '10
From Maitland, NSW
Oh yeah, the wheels themselves jacked up don't have play.
You said,
Theres no sound from the RIGHT at all, and doesn't happen when i turn Right either.
Unless i'm misinterpreting your words haha.
post Nov 2, 2010 - 12:46 AM
blu94gt
Joined Mar 23, '05
From Kansas City
QUOTE (Timmyface @ Nov 2, 2010 - 12:39 AM) *
You said,
Nope lol sorry that's my fault I was forgetting that passenger side in your car is the left. So left bearing making noise. Either way, there's only so many things that can make a scraping sound like that.
1999 Celica GT
post Nov 4, 2010 - 1:33 PM
Tigawoods
Joined Dec 22, '06
From Columbia, MD
wheels spacing making it rub up against the inside of the wheel well?
エキサイティングカーレーシングチーム!
post Nov 8, 2010 - 12:45 AM
dudeofchaos
Joined Dec 9, '08
From Blainville
I have the same prob. When it started to do so only a bit after this sound appeared the bearings started to squeek.
If it's not the problem I suspect maybe the cv axle?
I'll change all my 4 bearings if I can before I store it so I'll come back to you if I've done it and tell you if this was the problem.
Lo-Fi Version Time is now: June 24th, 2026 - 3:21 AM
