Nov 27, 2003 - 3:58 PM
Enthusiast ![]() ![]() Joined Jun 22, '03 From Toronto, Ontario, Canada Currently Offline Reputation: 0 (0%) |
So I lowered my car after a while.. just pulled the factory struts / whatever out and replaced them with with KYB Gr2's and Eibach Sportline's
There's this noise. I'm sure all you pros know what i'm talking about. Is there some add-on kit that I should added .. or some dampener or something that I forgot to install that was extra to what I listed?! Lemme know Thanks a million Shaun |
Nov 28, 2003 - 12:52 AM
Enthusiast ![]() ![]() ![]() Joined May 5, '03 From Toronto Currently Offline Reputation: 3 (100%) |
could be bushings if you're lucky. but probably top mounts, just because they cost more.
Nov 28, 2003 - 1:21 AM
What does this noise sound like?
Nov 28, 2003 - 4:28 PM
Kinda like a knock knock knock.. only heard at low speeds...
and .. mounts? Where can I get ones that'll hit the 1.5" Eibach Sportline drop? Do the factory ones work fine? And what type of bushings? Thanks guys. Shaun |
Nov 28, 2003 - 4:38 PM
Enthusiast Joined Jun 15, '03 From lexington, north carolina Currently Offline Reputation: 0 (0%) |
my car did this until i put a camber kit on it
Nov 28, 2003 - 4:46 PM
![]() Enthusiast ![]() ![]() Joined Jan 3, '03 From South Carolina Currently Offline Reputation: 0 (0%) |
Most likely your sway bar links. Mine did it for awhile till I took her to the shop and found out what it was. Easy fix with some new links or new sway bars.
J This post has been edited by Jussimple: Nov 28, 2003 - 4:47 PM |
Nov 28, 2003 - 7:58 PM
Enthusiast ![]() Joined Apr 6, '03 From Gainesville, FL Currently Offline Reputation: 2 (100%) |
There should really be a sticky for this. It seems to be the #1 complaint whenever you lower your car.
It could be: 1. Bushings 2. Loose sway bar linkages 3. The springs may not be properly set Refer to this link for more detailed explanations Clunking Hope it helps. Jordan |
Nov 28, 2003 - 8:34 PM
Im going to say the links, same thing with me.... did anyone find a place to buy them cheap??
Dec 1, 2003 - 6:10 PM
Thanks guys! Much appreciated!
So.. the sway bar links? HOw exactly to I get around to fixing these? I'll be taking it into the shop when I get my drive axels replaced at the end of the month soooooo.. what should I say to them.. Thanks again!!! Shaun |
Dec 1, 2003 - 6:38 PM
Enthusiast ![]() ![]() ![]() Joined Aug 29, '02 From Dallas, Tx Currently Offline Reputation: 0 (0%) |
This is obviously but often overlooked....make sure everything is tight!!! Like everybody said, sway bar end links are an obvious one. Also make sure you check the upper spring perches. They will move unless really tight.
| Lo-Fi Version | Time is now: July 9th, 2026 - 1:28 PM |
