> Hesitation at High RPMs
post Jan 11, 2011 - 9:20 PM
captb
Joined Sep 23, '08
From Hawaii
Hi all, I just started having this problem 2 days ago. and its on and off. the car hesitates as if one of the cylinders isnt firing and it only occurs at rpms above 3k and when acclerating fast or when going up an incline. initially i thought it was the spark plugs but they look alright and so do the distributer cap. I was watching the rpms and i dont visibly see any changes at low and high rpms. so then i thought it may be the gears going bad but it occurs on all the gears, and it cant be the clutch because i dont feel any slipping or anything. the car was running a little low on oil but even after i added some it still occured. The engine light came up and im getting codes 12 and 13. which means i am misfiring right? im starting to think it may be my intake, and its misfiring because its running rich and not getting enough air when the engine is pushed. i installed the new filter (some generic brand) just a few months ago. I will continue to try and figure this out but just wanted some input from you all.
thanks.
post Jan 12, 2011 - 5:07 AM
808celica
Joined Feb 24, '07
From Oahu, Hawaii
12 1, then 2 G, NE signal (#1)
13 1, then 3 G, NE signal (#2)
Distributor is gonna fail soon. Same with mines, car will start at cold temp, but once warmed up something in the distrib with open and the car will hesitate then shut off. Car will crank and crank and crank but wont kick. Of course I'll hook a bradda up at work wink.gif just have cash and dont say a word. Both you and Luka aka. Mike are having problems with your distrib.........I wonder who's next in the HI wink.gif
Lo-Fi Version Time is now: July 8th, 2026 - 2:22 AM
