Jan 24, 2011 - 10:42 PM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
hey guys.. my door locks just started acting up tonight. here are the symptoms.
i open my door with the key.. i press the unlock button to let the passanger in.. the door unlocks, but then locks right away.. i manually unlocked the doors and then press the lock button.. it doesnt work. when i press the unlock button. it will unlock but then locks right after. i know its not the door jam buttons, because i went on both sides and pushed them in and out a few times to make sure they were not stuck. if anyone could help me out that would be awsome. -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Jan 25, 2011 - 12:16 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Dec 29, '05 From So-Cal Currently Offline Reputation: 12 (100%) |
check the wires underneath you...maybe it is loose...especially if you have an aftermarket alarm...
Jan 25, 2011 - 12:18 AM
i will check it.. i dont have an aftermarket alarm though.. also i did change the battery.. i dont think that would have anything to do with it though.
Jan 25, 2011 - 12:21 AM
Enthusiast ![]() ![]() Joined Jul 3, '09 From UT Currently Offline Reputation: 14 (100%) |
I might be wrong, but i think our door locks are activated by a ground pulse. You may have a short somewhere along the line. To test, get a volt meter and see if you get any voltage at the switch. If its a short, look at the drivers kick panel, thats where most of the wiring is located and has the highest probability of being damaged because it sees the most traffic.
This post has been edited by zonz540: Jan 25, 2011 - 12:24 AM |
Jan 25, 2011 - 12:22 AM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jul 12, '08 Currently Offline Reputation: 5 (100%) |
try removing and disconnecting the switches from the doors. check to see if the contacts are okay then put it back together. Sometimes the simplest things do the trick
if that doesn't work I can send you a link to the rs3000 alarm manual. you might just have to reprogram the system. Dont worry, thats easy too This post has been edited by enderswift: Jan 25, 2011 - 12:24 AM -------------------- ![]() |
Jan 25, 2011 - 12:25 AM
oh boy so much chrap i have been havin to put up with my baby haha i will try to look tomarrow.. im sick right now so it sucks going outside in the freezing weather
i dont have an alarm in my car though. try removing and disconnecting the switches from the doors. check to see if the contacts are okay then put it back together. Sometimes the simplest things do the trick if that doesn't work I can send you a link to the rs3000 alarm manual. you might just have to reprogram the system. Dont worry, thats easy too -------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
Jan 25, 2011 - 1:24 AM
It sounds like either an issue with the ground or the relay.
Jan 25, 2011 - 6:14 AM
Enthusiast ![]() ![]() Joined Dec 14, '10 From Lansing MI Currently Offline Reputation: 1 (100%) |
my doors would do that from time to time before i got an alarm installed hold the handle as if you were going to open the door and then unlock it or lock it while you have it held that usually fixes it
Jan 26, 2011 - 11:43 AM
fixed! woo. the little button that is pushed in when the door is shut was stuck.. stupid me for not seeing that. thanks everyone for all the advice.
| Lo-Fi Version | Time is now: June 10th, 2026 - 5:35 PM |
