> Ignition Problem???, Problem fixed!!! Thanks guys.
post Jan 25, 2011 - 11:26 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Hey guys,
I was re-routing my battery to my trunk yesterday and after everything was complete, everything started up fine and was getting power to everything. I have a 150 amp ANL fuses on each side of the re-routing power wire. So if there's a short on either side, I should be protected. THE PROBLEM: is after I got everything installed, I realized that none of my interior lights was working. The lights on the a/c panel & the gauges are working. Just the door lights, trunk interior light, and main dome light is out & not coming on at all. I checked fuses and all are fine, what else could be causing the lights to cut out? Any help would be appreciated.
EDIT: I believe now that my problem maybe an ignition problem. My headlights won't turn on, unless I turn my key all the way to the "on" position. Plus, now I am getting a "hard start." Like my battery is about to die, but I just put in a new one when I relocated my battery position. I'm thinking, maybe it's a relay or something like that? Please, I need your help!
-Thanks, Ryan
This post has been edited by str8thugginit4ya: Feb 7, 2011 - 1:48 PM
post Jan 25, 2011 - 11:36 AM
95CelicaST
Joined Feb 5, '05
From pineapple under the sea
Did you actually test the fuses? Or just a visual check? I've had some die that looked fine.
**** Photobucket
post Jan 25, 2011 - 11:44 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Just visually. I was thinking it was a fuse problem, but all of them were visually fine. How else can i check the fuses? Oh, and which fuse is the fuse for the interior lighting? Is it the "dome" fuse that is located under my hood?
-Thanks, Ryan
post Jan 25, 2011 - 12:44 PM
mkernz22
Joined May 10, '10
From MA
You check them by pulling them out and seeing if the metal piece in them is still connected or broken in two.
post Jan 25, 2011 - 1:24 PM
95CelicaST
Joined Feb 5, '05
Yeah I've had some that look fine, but are actually bad. Pull the fuse and replace it with a known good fuse of the same rating from another circuit in the car.
I don't remember what the interior light fuse is.. I don't have a celica anymore.
**** Photobucket
post Jan 25, 2011 - 5:00 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (mkernz22 @ Jan 25, 2011 - 1:44 PM) *
I know I'm not an expert at these things, but you got to give me more credit than that! LOL, I know how to VISUALLY check the fuses (Which is what you just recommended). What "95CelicaST" was telling me, was to TEST them. I don't really know how to test fuses, cause I never did that before. So he suggested this:
post Jan 25, 2011 - 5:30 PM
mkernz22
Joined May 10, '10
From MA
If the tab in the middle between the two prongs is broken, that means it's blown so there is no point in testing it then.
Just make sure the fuse you take out, the replacement one is the same color and has the same amp rating on it.
The one for the interior is either behind the panel under the dash or under the engine bay, you just have to search around
post Jan 26, 2011 - 8:06 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Ok, so I went & replaced a bunch of fuses, but still no lighting. The worst part is that I have my boost gauge & that's not working either. I really hate when I can't see how much boost is pulling. I took a test light & there is current running to the "dome" fuse, which I believe is the fuse for the inside lighting. But I don't know what else this could be. SOMEONE HELP!!!!
-Thanks, Ryan
post Jan 26, 2011 - 8:44 AM
mkernz22
Joined May 10, '10
From MA
The dome light has it's own fuse because I believe that the sunroof runs off that fuse as well.
With the old fuse panel that was under my dash, the previous owner did something to it so when I would drive with my driving lights on at night, they would go on and off from time to time. I replaced the whole interior fuse panel and it works like a charm now.
Maybe when you drilled the holes in the wall you hit a wire?
post Jan 27, 2011 - 8:22 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (mkernz22 @ Jan 26, 2011 - 8:44 AM) *
Didn't drill any holes, use pre-existing holes with grommets. Only thing I can think of is that I shorted something out and blew something besides a fuse, which I hope is not the case.
-Thanks, Ryan
post Jan 27, 2011 - 10:51 AM
mkernz22
Joined May 10, '10
From MA
When you open your doors does it make a bing, bing, bing sound?
post Jan 27, 2011 - 11:36 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Nope, the ignition is not working properly. It starts and everything fine, but if I have the key in the ignition and the door is open, no bing!
post Jan 27, 2011 - 2:00 PM
mkernz22
Joined May 10, '10
From MA
someone probably unplugged the wire that makes it bing when the doors are open, or they unscrewed the piece.
post Jan 27, 2011 - 4:59 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (mkernz22 @ Jan 27, 2011 - 3:00 PM) *
That can't possibly be it. Because the interior lights aren't turning on for nothing! Also, I was checking around and I can't turn on my headlights or anything like that unless I put my key in my ignition and turn it 2 clicks (I believe that's to the on position?)
-Ryan
post Jan 28, 2011 - 9:07 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Could it be an ignition relay or something like that?
-Ryan
post Feb 1, 2011 - 8:46 AM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
Bump! Please help, I am out of ideas.
-Thanks, Ryan
post Feb 1, 2011 - 11:06 AM
tjblacrosse
Joined Oct 25, '07
From Eagan, MN
We just talked a little about this so I thought I'd write out the steps I would take:
- Batt. Health and Charge
- Fusible Link and Fuse check (use an ohmeter if you can get your hands on one!)
- Check your relays for proper continuity
- Check your connections you made to your battery relocation (grounds, to alternator, etc)
- If you have messed or played with any other electrical connections on the car, go back and check to see if they are good
Work your way back through the process you took relocationg your battery and make yourself a checklist so you don't overlook any steps. You'll find the problem eventually, just go through the circuit from top to bottom. I pulled up a power source chart for you, so you can see visually how the power flows. Good luck!
-Tyler
post Feb 1, 2011 - 12:07 PM
Neon90424
Joined Jan 19, '11
From Paraguay, Winchestertonfieldville
I had the bing bing bing thing removed it was driving me nuts, I have had problems where my dash clock didnt work or any of the accesories but it was just a fuse i believe
post Feb 1, 2011 - 8:01 PM
trdproven
Joined Aug 2, '05
From Guam
theres also a fuse that is labeled "X" you may want to check that one.
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Feb 3, 2011 - 12:30 PM
str8thugginit4ya
Joined Dec 11, '07
From Davie, Florida
QUOTE (trdproven @ Feb 1, 2011 - 9:01 PM) *
A fuse??? Where is that located?
-Ryan
Lo-Fi Version Time is now: August 11th, 2026 - 7:23 PM
