> Engine Mounts, Can't Find the right one for the rear
post Jan 28, 2011 - 1:16 AM
barterj
Joined Aug 28, '08
From Woolwich, Maine
back ground, last summer i replaced the front and rear motor mounts. The front one went in without a problem, however the rear which was supposedly meant for the GT with MT didn't bolt in, the studs were too short. The store said that the mounts for automatic and manual transmissions may have been listed backwards. I ended up getting the listed for the automatic transmission. Near the beginning of december the engine started knocking around again, so i took a look and the mount has ripped straight down through the rubber. I know the mount is really made for the auto trans cause it has significantly less rubber, but it was the only one of the 2 that would bolt in. I got the mounts from CarQuest.
Has anyone else experienced this problem and does anyone know what auto parts store will have the rear motor mount with studs long enough to bolt in?
This post has been edited by barterj: Jan 28, 2011 - 1:13 PM
post Jan 28, 2011 - 1:15 PM
barterj
Joined Aug 28, '08
Am I really the only person that has bought a new mount that the studs were too short? the reason I ask where someone may have gotten one that bolts in is that a lot of auto parts stores get their parts from the same places.
post Jan 28, 2011 - 8:09 PM
Remy
Joined Jan 25, '06
From MN
I bought mines from the dealer genuine toyota oem mounts, the oem mounts cost only about $20 or so more worth it imo..
post Jan 28, 2011 - 8:23 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
yeah, go oem. always.
post Jan 28, 2011 - 8:48 PM
yup, oem is the way to go, i have an old one i believe. not sure, ill look.
post Jan 29, 2011 - 12:56 PM
barterj
Joined Aug 28, '08
I usually go CarQuest for parts because my father has a garage account there, but I guess not for motor mounts anymore, thanks for the advice
post Jan 29, 2011 - 1:10 PM
sixgentoyota
Joined Aug 27, '10
From 60152
Urethane mounts are the best in my professional experience. Thats what i use on my cars and I have never had a problem.
Im not sure how makes them for the Celica but I will look and repost something.
Jake
The Mechanic
post Jan 29, 2011 - 1:16 PM
sixgentoyota
Joined Aug 27, '10
From 60152
http://www.6gc.net/forums/index.php?showtopic=39891
Someone on the forum already did it take a look these are just inserts but I thank you will like it. Im going to get some in the spring seeing as i just put a new motor in my 94 st from STAMBO
post Jan 31, 2011 - 6:44 AM
trdproven
Joined Aug 2, '05
From Guam
manual mounts have more legs than the automatic mounts, thats your first key to distinguish what you have. automatic mounts I've used before at one point but switched to manual later after my swap. they both fit but manual mounts appear to be more durable with the extra legs. Much easier to go with OEM catalog because a lot of times aftermarket replacement catalogs are fond of incorrect part numbers, or universal parts used for other cars. Its easy to notice what is different between OEM and aftermarket stuff, things are not shaped the same, too long or too short, etc.
This post has been edited by trdproven: Jan 31, 2011 - 6:48 AM
94 Celica GT
04 Celica GT
89 Supra (Sold)
90 Supra (Sold)
post Jan 31, 2011 - 1:29 PM
stephen_lee
Joined Mar 22, '07
From Houston, TX
oem = designed for application
aftermarket = compatible(mostly) with application
oem is really the best way to go.
Lo-Fi Version Time is now: September 4th, 2026 - 1:12 AM
