> What's this noise?
post Mar 11, 2011 - 7:51 PM
HectortheRican
Joined Dec 26, '09
From Albuquerque, NM
http://www.youtube.com/watch?v=kYbohL72m0I
The first couple seconds is me showing where the noise is generally coming from, but you can hear it as well. It's a popping noise. Then I put the mic closer to hear it louder. What could that be?
June '12 COTM
'95 AT200
post Mar 13, 2011 - 2:53 AM
HectortheRican
Joined Dec 26, '09
Anybody have an idea?
June '12 COTM
'95 AT200
post Mar 17, 2011 - 8:42 PM
HectortheRican
Joined Dec 26, '09
No one?? lol
June '12 COTM
'95 AT200
post Mar 17, 2011 - 11:06 PM
k-weaver
Joined Jun 5, '07
From Santa Maria
sounds like your timing belt cover is loose. Apply pressure to the cover and see if the sound goes away.
post Mar 19, 2011 - 11:09 AM
xrav22
Joined Jul 24, '08
From Canoga Park CA.
QUOTE (k-weaver @ Mar 17, 2011 - 11:06 PM) *
I have the same sound when my ac is on. I think we have an airpump hidden down somewgere for additional vacume.
post Mar 19, 2011 - 11:40 AM
block
Joined Jul 27, '06
From Soda
did you replace your waterpump?
post Mar 19, 2011 - 3:48 PM
HectortheRican
Joined Dec 26, '09
QUOTE (block @ Mar 19, 2011 - 10:40 AM) *
Yeah. I did timing belt and water pump about 3k miles ago.
Another thing, this noise only comes out when I'm at nominal temperature.
June '12 COTM
'95 AT200
post Mar 19, 2011 - 4:30 PM
Its the trans coupler inverter shaft bearings behind the oil pump, for sure.
post Mar 19, 2011 - 5:28 PM
HectortheRican
Joined Dec 26, '09
QUOTE (Bitter @ Mar 19, 2011 - 3:30 PM) *
All I thought when I read that was "so it's the flux capacitor..." lol
What exactly are those?
June '12 COTM
'95 AT200
post Mar 19, 2011 - 6:48 PM
D-Man
Joined Jan 18, '08
From Houston
Belt dont have no knicks does it?
and only a Normal operating temp? It's for sure comming outta the belt area? could be some of the componet bearings.
Damn D-Man - most impressive.
post Mar 19, 2011 - 8:01 PM
HectortheRican
Joined Dec 26, '09
QUOTE (D-Man @ Mar 19, 2011 - 5:48 PM) *
Seems likely... Previous owners sound like they didn't know what "maintenance" meant. I'm just fixing things as they break. The belts are good. And yeah, it's definitely coming from that area and only at nominal temp, which means about 750-900rpm
June '12 COTM
'95 AT200
post Mar 19, 2011 - 9:06 PM
just for giggles...get it warmed up, take the accessory belts off (I know, a pain) and then run the engine. If it still makes the noise it could be a timing belt idler or tensioner pulley bearing making noise. Sometimes they only make noise at a specific RPM or at high speeds the belt has enough force to make them spin.
post Mar 19, 2011 - 10:09 PM
D-Man
Joined Jan 18, '08
From Houston
^^^ got a point- but STOOOOPIDLY unlikely. not to be confused with impossible. We've all seen stranger.... lol
QUOTE (HectortheRican @ Mar 19, 2011 - 8:01 PM) *
Try to zero in to a certin part. if you can find it down to be the alt/PS pump/ect. then you got a sold ground to stand on. ANY Click nose comes with a Vibration. Just a first though. (it's how i do it)
worse case- Gimmie call. You got my new number still, yeah? I'll help you out man.
post Mar 20, 2011 - 2:36 AM
HectortheRican
Joined Dec 26, '09
QUOTE (D-Man @ Mar 19, 2011 - 9:09 PM) *
Nah, I don't have your number. Facebooks! But yeah, I'll warm her up soon and give it another listen.
June '12 COTM
'95 AT200
post Mar 20, 2011 - 9:43 AM
not that unlikely, but somewhat unlikely for that kind of knocky noise. Not impossible though....
Lo-Fi Version Time is now: August 11th, 2026 - 5:03 PM
