> Harness Same for Obd1/2?
post Mar 20, 2011 - 3:19 PM
96stgreendemon
Joined Oct 7, '09
From Northern kentucky
Curious as to if i can use a harness from and obd1 harness for my car that is obd2 when i swap so the car is not down as long, so are they the same from a 94 to a 96?
2001 Solar yellow Lexus IS300
post Mar 21, 2011 - 6:39 AM
96stgreendemon
Joined Oct 7, '09
Bump for help, don't want to waste my money
post Mar 21, 2011 - 7:14 AM
bloodMoney
Joined Aug 4, '06
From Chicagoland
I don't think so. IIRC, the OBDII harness has a cam/crank angle sensors while the OBDI harness just has the cam position sensor integrated into the distributor. Without the crank angle sensor, you will throw a CEL. There might be other differences, but I definitely know that.
~bloodMoney
post Mar 21, 2011 - 7:22 AM
there are harness diffrences between the 2.
post Mar 21, 2011 - 9:17 AM
96stgreendemon
Joined Oct 7, '09
the harness is going to be used for a 3s swap, so im not sure if the CAS will matter or not
post Mar 21, 2011 - 9:46 AM
send a PM to Dr Tweak, he will know the answer
post Mar 22, 2011 - 7:39 AM
if your doing a 3rd gen swap, it dont matter, you dont use the 5s harness at all. (at least i dont when i do them..cant speak for anyone else.)
post Mar 22, 2011 - 9:52 PM
96stgreendemon
Joined Oct 7, '09
Yeah figured that out, talked to tweak and he said the same thing about not needing the orginal harness
Lo-Fi Version Time is now: August 30th, 2026 - 11:17 AM
