Mar 25, 2011 - 1:33 AM
Correct me if I'm wrong.
I know STs are kind of notorious for having a rough idle, but I only experience a rough idle when the motor dips below about 900rpm. I've heard of bad motor mounts being the problem, but why would my motor have a super smooth idle before 900rpm? Seems to me that the engine works less at lower rpms, thus making less vibrations. So what I think might be happening is possibly a clogged/semi-clogged catalytic convertor. When I thought about it, it made sense. When my motor is at higher idle rpms (1,000-1,200), the exhaust velocity is high enough to smoothly overcome the clogged cat, but once it dips below the threshold of my rough idle, the exhaust velocity isn't enough to overcome the clogged cat, and it struggles to get through. It seems pretty reasonable and likely to me, but I'm not a master mechanic, I just have a basic, above-average knowledge of cars. Any input would be great. This post has been edited by HectortheRican: Mar 25, 2011 - 1:56 AM -------------------- taking too long to mod since '09
June '12 COTM '95 AT200 |
Mar 25, 2011 - 2:33 AM
Enthusiast ![]() ![]() Joined Feb 26, '11 From beaufort,SC Currently Offline Reputation: 0 (0%) |
mine has a little rough idle and i have no cat.......stock resonator and muffler though....been like this since i got the car...
Mar 25, 2011 - 10:56 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Jun 18, '09 From Orlando Currently Offline Reputation: 8 (100%) |
Same here, BUT, only in drive. It rarely likes to dip in neutral. I experience the same drop in RPM sometimes, usually when it's hot or cold and some accessories are on.
This post has been edited by SwissFerdi: Mar 25, 2011 - 10:56 AM -------------------- '97 ST \ Eibach \ KYB \ Kenwood \ Alpine \ Cusco \ OEM+ [sold 10/18]
'90 MX-5 Mariner Blue '93 MX-5 LE '07 Kawasaki Eliminator 125 silver '15 Optima Grey '04 206 GTi silve |
Mar 25, 2011 - 11:42 AM
Enthusiast ![]() ![]() ![]() ![]() Joined Apr 17, '10 From U.P. michigan GO STATE Currently Offline Reputation: 3 (100%) |
yup same here in the gt, i have no cat and it still shakes a bit. more with accessories on like swiss said.
-------------------- It takes 8,460 bolts to assemble an automobile, and one nut to scatter it all over the road.
![]() Celica: The name is derived from the Spanish word for "heavenly" or "celestial". Back-2-Back July COTM 15&16 |
Mar 25, 2011 - 11:55 AM
Because IIRC, Kyle (96stgreendemon) had a rough idle like me, replaced his cat, and it went away.
Mar 25, 2011 - 12:04 PM
in your case it could be, all cars are different and mabey it is just the cat in your. only one way to find out right lol
Mar 25, 2011 - 12:06 PM
Exactly. I'll find out in the summer when I go back to Texas. I'll be doing my header then, that way I actually have a place to put the stock manifold in. Lol
Mar 25, 2011 - 5:50 PM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Mar 22, '07 From Houston, TX Currently Offline Reputation: 4 (100%) |
add a 330 ohm resistor inline with the ecus coolant temp sensor. its the 2 wire CTS on the water neck kinda pointing towards the throttle body.
this will raise idle to about 1000 in neutral, and 800-900 in gear. if you think thats a bit much try the next smallest resistor. -------------------- QUOTE "And, as always, your friendship, help, and dedication to the advancement of Texas Celica dominance is GREATLY appreciated. Thanks bro." -DEATH 1994 GT: V6 swap, 5speed E53 W/ LSD, All Power, now RED 1995 ST: SOLD @273k miles, Auto, all power, CarPC, White 1994 ST: Totaled, 5spd, all power, Red RIP 07/09/09 @ 241,810 1994 Lexus LS400: This is my new DD |
Mar 25, 2011 - 9:48 PM
add a 330 ohm resistor inline with the ecus coolant temp sensor. its the 2 wire CTS on the water neck kinda pointing towards the throttle body. this will raise idle to about 1000 in neutral, and 800-900 in gear. if you think thats a bit much try the next smallest resistor. I'll hold off on doing that until I replace my cat in late May. -------------------- taking too long to mod since '09
| Lo-Fi Version | Time is now: August 27th, 2026 - 4:43 AM |
