Mar 26, 2011 - 2:42 AM
Enthusiast ![]() ![]() Joined Jan 3, '06 From The Netherlands Currently Offline Reputation: 6 (100%) |
Hey guys,
For almost 2 weeks now, my st205 has got a strange whistle when at idle. At first i thought it was a slippery belt, but that is certainly not the case. Then i thought it may be a vacuum leak, but boost is good all the way to red line and the whistle is only there when at negative vacuum. It occurs only after lets say 15 minutes or so and disappears when hitting the throttle a little. Could it be a bearing from the powersteering or aircon pump? It looks like the sound comes from that area. Any thoughts? -------------------- JDM ST205
Mar 26, 2011 - 11:10 AM
it could be one of the idler pullys, or the PS or AC bearings...you need to get in there and pinpoint the noise.
Mar 26, 2011 - 11:42 AM
mine was doing something similar, it was because I was low on PS fluid, I added some and voila !
Mar 27, 2011 - 8:44 AM
Checked all the bearings of all pulleys, and it turned out te be the no.1 idler pulley. Although the timing belt was replaced by the previous owner, he did not replace the tensioner and the pulley. Is there possibility the idler pulley by itself can be replaced without tearing down half the engine? Anyone with a kind of how-to maybe?
Mar 29, 2011 - 3:20 PM
![]() Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 7, '03 From Northern Virginia Currently Offline Reputation: 23 (100%) |
you're going to have to remove the timing belt to change it, might as well change it all out anyways.
how to... http://gtfours.co.uk/ > How to... > Repair/Maintain > Change the Cambelt |
Apr 2, 2011 - 7:22 AM
Yeah, mr. T told me the same yesterday! Grrrrr...
The 11th of april the whole timing assembly will be replaced. -------------------- JDM ST205
Apr 2, 2011 - 8:04 AM
Enthusiast ![]() ![]() ![]() ![]() ![]() Joined Feb 1, '05 From Charlotte NC Currently Offline Reputation: 14 (100%) |
before you change everything out, check one more thing, your intake manifold gasket. if its a real high pitched whistle (like tea kettle) it could be that. i had the same problem from my intake manifold (between block and manifold) when i would accelerate or car would be warm it would disappear but return at idle.
| Lo-Fi Version | Time is now: August 26th, 2026 - 11:22 PM |
