> map sensor problem, boost
post Apr 3, 2011 - 5:00 PM
TRD11
Joined Feb 27, '11
From trevorton pa
hey guys i have a major problem with my map sensor it will only read 5 psi and fall on its face ....... i no its not ment to read boost so what am i dealing with ?????? what map do i need to get ??????????? and im only runing a fmu so i need a map that will work with no tune .....HELP >>>>>> 96 celly gt 5sfe st204
This post has been edited by TRD11: Apr 3, 2011 - 5:05 PM
cant stop wont stop
post Apr 3, 2011 - 5:42 PM
Your gonna blow up your motor the way your running it.
Ditch the fmu, get the 460cc rx7 injectors the 5sfte guys use, an safcII, and a 2 bar map sensor outta a 90-93 alltrac or mr2t.
post Apr 3, 2011 - 7:58 PM
TRD11
Joined Feb 27, '11
From trevorton pa
hey thanks i whent the fmu way becouse i had no idea what would work for the 5sfe but now i do ............ thanks ........ it really helped
cant stop wont stop
post Apr 4, 2011 - 8:53 AM
the stock MAP sensor is behaving exactly like it should. its seeing boost and its not supposed to so it shuts down the ECU. you need a piggyback like the mentioned AFC or the AEM FIC that can take the stock signal and manipulate it and fool the ECU.
Lo-Fi Version Time is now: August 26th, 2026 - 4:28 PM
