Apr 14, 2011 - 12:34 PM
Enthusiast Joined Sep 6, '10 From Lancaster, CA Currently Offline Reputation: 1 (100%) |
In second, third, and fourth gear, when I'm accelerating, I seem to lose power around 3k rpm. It doesn't completely die off, but I can tell I'm not accelerating as fast as I was. After a couple hundred rpms it kicks back in. The problem seems to fall off the warmer the engine gets or the higher gear I'm in. When the engine has been running for a while the problem is a lot less noticable, but is usually still present. Any ideas? Thanks.
Apr 14, 2011 - 12:54 PM
Enthusiast ![]() ![]() Joined Apr 24, '07 From CA Currently Offline Reputation: 1 (100%) |
Maybe your clutch is slipping
-------------------- QUOTE what hes saying is if you put blue lights in you car youll lose hp. |
Apr 14, 2011 - 1:43 PM
start with a tune up on the ignition components (ie. spark plugs, wires, distributor cap).
Apr 18, 2011 - 12:57 PM
I don't think its the clutch. Its predicatable when it happens. It doesn't seem to happen in first gear, and that is where all my torque is. If it was going to slip I think it would slip there.
I also just replaced all my spark plug wires because one was intermittenly working. The problem I have now is not like that. The hessitation is not real quick like a spark plug not firing, and the engine sound doesn't change like its miss firing. It happens for a couple seconds, and always in the same rpm range (2500 to 3000). The colder the engine the more it happens too. So I don't know what that has to do with it. |
Apr 18, 2011 - 5:21 PM
Maybe a new air filter, clean & gap your plugs, possibly run injector cleaner and just floor it everywhere? If you do be sure to change your fuel filter after
-------------------- Mike W
Apr 21, 2011 - 10:14 PM
Enthusiast ![]() Joined Oct 29, '04 From Sierra Vista, Az Currently Offline Reputation: 0 (0%) |
Maybe a new air filter, clean & gap your plugs, possibly run injector cleaner and just floor it everywhere? If you do be sure to change your fuel filter after had the same problem with my 95. turned out I flush and refill my trans fluid/gear oil. worked like a charm. -------------------- Celica Enthusiast with no experience. LoLs Looking for people closer to my area to talk/work on projects, let me know if your near 85635 Sierra Vista, Az
Apr 22, 2011 - 1:48 AM
if it sounds like a bogging down sound maybe? (like when you accelerate through a puddle)
Apr 22, 2011 - 12:54 PM
Enthusiast Joined Dec 5, '09 From Harlingen, tx Currently Offline Reputation: 0 (0%) |
could it also be the EGR valve? my car is doing the same thing, 7afe auto trans. i plugged a comp in and it gave me a triggered sensor in my EGR.
| Lo-Fi Version | Time is now: September 15th, 2026 - 9:26 AM |
