Apr 20, 2011 - 7:24 PM
Enthusiast ![]() ![]() Joined Sep 11, '08 From Surrey Unitedkingdom Currently Offline Reputation: 1 (100%) |
Just want to get a little help in wireing a SAFC II up to my 3SFE which has recieved a CT26. Will only be running actuator boost - 7psi, so nothing big. Running through a ST185 intercooler mounted in front with suitable mods. Will be retarding timing by about 5 degrees. Red - Power Brown - Ground, ECU side Black - Ground about 1 cm after brown Green - RPM Grey - Throttle Signal Purple - knock White - Airflow pressure Signal Input Yellow - Airflow pressure Signal Output Blue - not used Pink - not used Orange - not used Am I right with this? Please correct if not........ |
| Lo-Fi Version | Time is now: August 30th, 2026 - 8:25 PM |
